em có con 1202 bị nước vào có 1 ít thôi nhưng ko hiểu sao bây giờ màn hình nó bị trắng,em đã thay màn hình mới rồi ,lắc lại cpu và flash rồi nhưng mà vẫn ko được mong các anh chỉ giúp em cách giải quyết![]()
				Getting MCU ID
MCU ID: 0x2293
First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 03.10
21-01-09
RH-112
(c) NMP
HW version: 2000
PCI version:
UEM version: 1328
UPP version: 8851
RFIC version: 0700
DSP version: ICPR81_08w31_UPP
LCD version: UNKWN: IDs:
00:ff:00
PPM version: V 03.10
21-01-09
RH-112
(c) NMP
EL
ADSP SW version: V 03.10\n21-01-09\nRH-112\n(c) NMP\nel
Production serial number: IET862356
Product code: 0563390
Module code: 0204036
Basic production code: 0558505
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 353211036962344
IMEI spare to net: 3A 35 12 01 63 69 32 04
IMEI SV to net: 33 35 12 01 63 69 32 14 F5
Master Code: 3745506060
Phone type: RH-112, Software version: 03.10, Language Pack: EL
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-112.ini
Checking path: C:\Program Files\Nokia\Phoenix\Products\\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\\
No ini files found...
Done!
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.100
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.10el
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh1120_nai03.10el
Setting local mode...
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.100
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 84B60EA2294501FFABD0E2A1CE
MSID decoded: 3E4EBAE9000ADE36A8000000
FAID: E4312365517FB80EB0043674
Erasing...
Found 5 interval(s) to erase
Operation took 1 minutes 5 seconds...
Writing...
Perm. Data Restore OK
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.10el
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 8485C4F8AF41C7C923DE4BCA28
MSID decoded: 3E4EBAE9000ADE36AA000000
FAID: 6741A7C5A6E97BD167B96BA5
Erasing PPM...
Found 2 interval(s) to erase
Operation took 0 minutes 21 seconds...
Writing...
Operation took 0 minutes 6 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh1120_nai03.10el
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 22 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
IMEI: 353211036962344
Product Code: 0563390
Resetting PPC...
Done!
				em chạy lại phần mềm và đưa log lên đó rồi các anh tham khảo giup em với nhé .em thank các anh nhiều
ngocminh_dtdd (09-11-2009)
				vâng đễ em thử xem sao đã anh nhé .thank anh nhiều
				các anh đã biết nó bị bệnh gì chưa vậy.bác nào có sơ đồ câu màn hình ko cho em với
ATO:
Default SN type:
pm của bạn bị lỗi
0933.379.527
				thế bây giờ phải chạy lại hả anh , anh có ppm nao của dòng máy này ko chuyến cho em xin đi
