máy rớt đất bị mất sóng em bỏ luộc nó cái mất nguồn luôn cái log nó nè xem giúp giùm em cái:
MCU ID: 0x3162
FLASH ID0: 317E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
First 16 bytes: AD 7E B6 1B 00 FF 10 40 00 00 00 00 00 00 00 00
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: D:\F\file nokia\dtc4\1680c rh_394\1680c RM-394_6.82\rm394__06.82.mcusw
Phone Type:
PPM Flash file: D:\F\file nokia\dtc4\1680c rh_394\1680c RM-394_6.82\rm394__06.82.ppm_v
Phone Type:
CNT Flash file: D:\F\file nokia\dtc4\1680c rh_394\1680c RM-394_6.82\rm394__06.82.image_v
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: D:\F\file nokia\dtc4\1680c rh_394\1680c RM-394_6.82\rm394__06.82.mcusw
Booting phone...
MCU ID: 0x3162
Boot size is 0x09A8
Boot is ready...
FLASH ID1: 317E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 11
Flash ID is 0x7E310100
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x7528; Loader chk: a2
Loader is ready...
MSID: 84A3ADBD756427FD6A8187F161
MSID decoded: 2C40BAE9001F451EAA000000
FAID: FE57543F1A7B7755578F879A
Operation took 0 minutes 6 seconds...
Erasing...
Found 2 interval(s) to erase
Erasing area: 01020000 - 01C3FFFF...
Error erasing area: 01220000 - 0123FFFF
