Kết quả 1 tới 4 của 4
    ĐÔ LƯƠNG _ NGHỆ AN
    Mặc định giúp em với 1661 vất vả quá
    em nhận mở mạng giờ nó thế này đây các anh giúp em với
    Getting MCU ID
    MCU ID: 0x2293
    FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    Phone Type:
    FILES SET FOR FLASHING:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-122\rh122_004.300
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-122\rh122_004.30mg
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-122\rh1220_nai04.30mg
    Setting local mode...
    Reading IMEI...
    Reading IMEI data...
    IMEI data corrupt...
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\rh-122\rh122_004.300
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0xC0882000
    Loader size is 0x4B38; Loader chk: 47
    Loader is ready...
    MSID: 84D3C9B81B5C5DB72322146388
    MSID decoded: 3E4EBAE900DBD269AA000000
    FAID: 65E987A4490E0A2271215DFC
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 01010000 - 0179FFFF...
    Erasing area: 017A0000 - 017EFFFF...
    Erasing area: 01F00000 - 01FDFFFF...
    Operation took 1 minutes 36 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 15 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\rh-122\rh122_004.30mg
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 843EEB43FB2BFEAC6A41224275
    MSID decoded: 3E4EBAE900DBD269A9000000
    FAID: 47F09657A7B5FA49FAEAD365
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 01250000 - 0125FFFF...
    Erasing area: 01260000 - 0174FFFF...
    Operation took 1 minutes 0 seconds...
    Writing...
    Operation took 0 minutes 23 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\rh-122\rh1220_nai04.30mg
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 84D024C8C9C611D23C8ED2B822
    MSID decoded: 3E4EBAE900DBD269A8000000
    FAID: E236A2CC933B69BBEDA448ED
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01750000 - 0178FFFF...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 3 minutes 39 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-122, Software version: 04.30
    IMEI: 351943038780546
    Product Code: 0575936
    Resetting PPC...
    Done!
    Powering the phone...
    Unlocking...
    ASIC: b
    SW version: 04.30
    Unlock not supported!
    Failed! Aborting!
    Thành viên chính thức ducmap@'s Avatar
    Sep 2007
    bông trang
    Thay cpu 1200 vô dùng hwk nạp nó you.
    sống trên đời này bạn cần phải có một tấm lòng,,và sau đó,,
    V.I.P ThienKim GSM™'s Avatar
    Thành phố Dệt
    Ngồi chờ support hoặc thay UPP( chắc JAF sẽ support khi có 1.98.70)
    Thành viên kỳ cựu thanhcong mobile's Avatar
    thay upp 1200 mới unlock được bạn ơi,còn ko ngồi chờ thôi
  1. cần giúp nạp pm 1661-2 báo lỏi
    By bao_mc in forum DCT4 - WD2
    Bài viết cuối: 16-12-2013, 20:10
  2. Cách chuyển 1661-2b to 1661-2
    By ThanhHai_GSM in forum DCT4 - WD2
    Bài viết cuối: 01-05-2011, 10:53
  3. xin giúp 1661
    By transinco1_5 in forum DCT4 - WD2
    Bài viết cuối: 15-04-2010, 14:19
  4. Trả lời: 1
    Bài viết cuối: 30-12-2009, 23:05
  5. 1661 mở mạng cần giúp đỡ
    By SyChien_Mobile in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 08-11-2009, 14:04
