FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 05wk07v48.1
28-08-07
RM-180
(c) Nokia.
PCI version:
RFIC version: 150a160f
DSP version: rolf_espresso_05wk07v29p1
LCD version: 2727964
APE SW Core version: V 5.0741.4.0.1
08-10-07
RM-180
(C)Nokia
APE Variant version: 5.0741.4.0.1-APAC2
08-10-07
RM-180
(c)Nokia.
Retu version: 32
Tahvo version: 52
APE HW version: 256
APE ADSP SW version: 16054
Production serial number:
Product code:
Module code:
Basic production code:
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 359400003043725
IMEI spare to net: 3A 95 04 00 30 40 73 02
IMEI SV to net: 33 95 04 00 30 40 73 02 F8
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-180.ini
Setting local mode...
Reading product code...
Product Code:
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-180\
Scanning for ini files...
INI file .ini is missing. Continue searching for second ini type...
No ini files found...
Done!
lúc đầu máy khởi động trắng màn hình, flash lại không ok
em xoá full nạp lại thì khởi động lên hiện Phone startup fails - Contact retailer
mong các cao thủ ra tay giúp em, thank nhiều...
