    Thành viên tích cực mt_gsmvn's Avatar
    Jan 2009
    Khu lấn biển
    Mặc định 1200 asic 00
    hiện trạng là máy mở nguồn lên logo nokia treo 1 chổ.máy đã mất asic nên em ko cách nào unlock được.đã erase full rồi nạp lại vẫn vậy.Các bác nào có gặp trường hợp rồi giúp em với nhé.
    Đây là log chạy JAF:
    Getting MCU ID
    MCU ID: 0x2292
    First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Failed! Aborting!
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.910
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.91mr
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh990_nai5.91mr
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.910
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x28882000
    Loader size is 0x4B38; Loader chk: df
    Loader is ready...
    MSID: 8417E1339B85C3F328ECBC2361
    MSID decoded: 3E4EBAE90086D1D9A8000000
    FAID: E5CF7E04A56983EF66257A9A
    Erasing...
    Found 5 interval(s) to erase
    Operation took 1 minutes 14 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 13 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.91mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Operation took 0 minutes 23 seconds...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh990_nai5.91mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 84EF1608A97DFD00DE77FFDCEC
    MSID decoded: 3E4EBAE90086D1D9AA000000
    FAID: C17428DEC61C8B11607291A6
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 3 minutes 8 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-99, Software version: 5.91
    IMEI: 353109023227475
    Product Code:
    Resetting PPC...
    Done!
    Unlocking...
    Failed! Aborting! Asic 00
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    thay flassh chạy lại xem sao anh .
    Jan 2009
    Khu lấn biển
    đã thay 1 cặp uem rồi vẫn tình trạng ASIC 00.
    Aug 2008
    Tui đã bảo ông thay CPU đi cơ mà ko nghe hả,chém đó
    1 ăn 9 thua thì cũng phải làm chứ
    Anh Minh Mobile
    32-Hoàng Diệu-Eakar-Dak Lak
    Thành viên mới vananhphone8181's Avatar
    ban thay cpu va láh roi ha
    dct4 ko thay duoc dau ban ah neu thay thi phai goi log chay lai thoi ban ah
  1. xin log imei 1200 asic 11
    By minhtu2326 in forum DCT4 - WD2
    Bài viết cuối: 14-10-2012, 20:26
  2. xin 1log 1200 asic 11
    By minhtu2326 in forum Phần mềm và các mã lệnh
    Bài viết cuối: 14-03-2012, 10:42
  3. xin log 1200 asic 11
    Bài viết cuối: 12-07-2011, 15:44
  4. xin 1 log 1200 asic 11
    Bài viết cuối: 10-06-2011, 10:40
  5. Nokia 1200 mất ASIC ???
    By tuandt2 in forum DCT4 - WD2
    Bài viết cuối: 21-04-2009, 17:03
