Kết quả 1 tới 10 của 10
    Thành viên mới minhlamdn's Avatar
    Oct 2009
    Mặc định nhờ các bác xem dùm lock 1202 hộ em
    máy dang sài bị contacservice.em chạy ct song xuôi rui nhung không uhlock duoc không biết nó bị gì nủa.nhờ anh em giúp
    MCU ID: 0x2293
    First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
    Checking path: \Products\RH-112\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.100
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.10il
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh1120_nai03.10il
    Changing flashing settings...
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.10mr
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh1120_nai03.10mr
    Setting local mode...
    Reading IMEI...
    Reading IMEI data...
    IMEI data corrupt...
    Failed to backup imei...
    Reading IMEI...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.100
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x28882000
    Loader size is 0x4B38; Loader chk: df
    Loader is ready...
    MSID: 84CC8474F2DA7D3FF49C26FD88
    MSID decoded: 3E4EBAE900E85939A8000000
    FAID: 32F6A73F2D6E62A6574A7AC1
    Erasing...
    Found 5 interval(s) to erase
    Operation took 1 minutes 3 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.10mr
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 84ABC4465C98F7766E953340EC
    MSID decoded: 3E4EBAE900E85939AA000000
    FAID: 92DFC38E37704C14C8791508
    Operation took 0 minutes 6 seconds...
    Erasing PPM...
    Found 2 interval(s) to erase
    Operation took 0 minutes 20 seconds...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh1120_nai03.10mr
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 20 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-112, Software version: 03.10
    IMEI: 356913031200821
    Product Code:
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Done!
    Done!
    Powering the phone...
    Unlocking...
    ASIC: b
    SW version: 03.10
    Unlock not supported!
    Failed! Aborting!
    Done!
    vói a máy bây giờ vẫn nhu cũ contacservice.máy bác cho em ý kiến vói ạ.em xin cam on tat cả
    V.I.P jerrylevu's Avatar
    Jun 2005
    sài gòn
    kiếm con cpu 1200 đóng vào con này chưa có box nào unlock được nó đâu .
    Moderator Thuyết Vũ's Avatar
    Gia lai
    Failed! Aborting!
    chưa có thiết bị support cho UPP em này. giải pháp là thay UPP 1200 vô rồi unlock!
    Iphone Shop Thu Vân-sửa chữa apple Chuyên Nghiệp
    507 Nguyễn Huệ Núi Sập Thoại Sơn An Giang.YM: phong_vugl mobile: 0974444438
    Tài Khoản Vietcombank Gia Lai chủ tài khoản : Vũ Tiến Thuyết 0291002263263
    Thành viên chính thức changtraigelo's Avatar
    bạn dùng thử cái này nhé
    trung tâm phá hủy mobile
  5. ( changtraigelo ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    cuong0110 (19-11-2009)
    Oct 2009
    chân thành cam on máy pác.de lam tìm cpu 1200 dong vào xem thế nào rùi thông báo sau.chuc anh em forrum một ngay làm viet duoc thât nhieu lua nhe hjhj
    Thành viên chính thức hoatygontim's Avatar
    mình dùng hộp UFS+HWK và dùng cáp cắm dưới đuôi flas và unlock được mà
    Jun 2005
    sài gòn
    Trích Được post bởi hoatygontim Xem bài viết
    Vậy bạn là nguời đầu tiên unlock 1202 bằng HWK đó ....
  9. #8
    e hèm em xem lại rùi hổng phải CPU 2293 hihi
  10. #9
    Thành viên kỳ cựu thanhcong mobile's Avatar
    con 1202 này làm anh em mình mệt thật,ko biết bao giờ box mới support con này nửa
  11. #10
    Thành viên mới haon178's Avatar
    chuc cac ban thanh cong
  1. kiểm tra dùm em 3gs Lock hay Wo
    By xuyenll in forum iPHONE 3Gs
    Bài viết cuối: 20-08-2013, 07:53
  2. nhờ ae lấy dùm 1 lock
    By duykhanh_gsm in forum DCT4 - WD2
    Bài viết cuối: 30-06-2013, 21:18
  3. nho anh em xem dùm em bản lock
    By phamcuongmobile_1990 in forum DCT4 - WD2
    Bài viết cuối: 16-12-2011, 15:45
  4. aec xem dùm em cái lock vs
    By mobjado in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 03-05-2011, 16:51
  5. n70 nhờ ae xem dùm lock
    By hà_vũng tàu in forum BB5
    Bài viết cuối: 22-12-2009, 09:35
