Kết quả 1 tới 3 của 3
    Thành viên chính thức anh0000's Avatar
    Mặc định 6230 thường cần giúp
    Getting MCU ID
    MCU ID: 0x1052
    FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: 003900EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9
    FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
    FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-12\
    Scanning for ini files...
    INI file .ini is missing. Continue searching for second ini type...
    Changing flashing settings...
    FILES SET FOR FLASHING:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.500
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50a
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50.ucp_a
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Languages in ppm: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.500
    Booting phone...
    MCU ID: 0x1052
    BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia
    Boot size is 0x2398
    Boot is ready...
    Flash ID is 0x22F800EC
    Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia
    Loader size is 0x84A0; Loader chk: 38
    Loader is ready...
    MSID: 84D5DFB18547D0D343E0818302
    MSID decoded: B03FBAE9001ED102A9000000
    FAID: 97633A1D5278C836AF5F115B
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 00000000 - 0000FFFF...
    Erasing area: 00010000 - 007FFFFF...
    Erasing area: 00800000 - 0093FFFF...
    Erasing area: 00B60000 - 00FEFFFF...
    Operation took 2 minutes 7 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 51 seconds...
    Restarting MCU...
    NAND Format FAILED!!!
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50.ucp_a
    Booting phone...
    MCU ID: 0x1052
    Boot size is 0x2398
    Boot is ready...
    Loader is ready...
    MSID: 84FA4290BB4ECB3970EE977BD6
    MSID decoded: 3E4EBAE9001ED102A9000000
    FAID: 8CD8741CD30459F66542351D
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 00940000 - 00B3FFFF...
    Operation took 0 minutes 18 seconds...
    Writing...
    Operation took 0 minutes 9 seconds...
    Restarting MCU...
    Extracting Content Pack...
    Error setting local mode...
    CP Extract Failed!
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50a
    Booting phone...
    MCU ID: 0x1052
    Boot size is 0x2398
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Operation took 0 minutes 19 seconds...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 5 minutes 50 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Nhờ ae cao thủ xem dùm em cái log nokia 6230 thường em chạy moi cách mà sao không done được. em xin cảm ơn ae cao thủ
    Tiền không là tất cả
    Nhưng tất cả chỉ vì tiền...hihihi
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    nếu vậy thì anh chuyển hộp khác chạy thử xem sao anh
  3. ( VŨ PRO ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    anh0000 (24-11-2009)
    Thành viên kỳ cựu tungculao's Avatar
    TCL.VN
    vầy nè. có gan thì làm theo nhe. khò 2 con cpu. và flash........ xoá full.nạp flash lại
  5. ( tungculao ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  1. 6230 cần giúp
    By nguyenvu333 in forum DCT4 - WD2
    Bài viết cuối: 13-02-2011, 11:41
  2. cần giúp 6230
    By Apple179 in forum DCT4 - WD2
    Bài viết cuối: 01-12-2010, 23:28
  3. 6230 cần sự giúp đỡ
    By anhphong012 in forum DCT4 - WD2
    Bài viết cuối: 29-06-2010, 13:27
  4. 6230 cần giúp
    By hungboro in forum DCT4 - WD2
    Bài viết cuối: 09-03-2010, 07:33
  5. 6230 xin giúp đỡ
    By trannhuy in forum DCT4 - WD2
    Bài viết cuối: 04-05-2009, 14:46
