Kết quả 1 tới 10 của 25
    Thành viên chính thức quangminh900's Avatar
    Aug 2008
    Hà Nội
    Mặc định nokia 1202 unlock
    anh em có ai unlock con 1202 của vina chưa
    JAF version 1.98.62
    Detected PKEY: 900096F0
    Card life counter: 99.99%
    Detected version: 01.B1, Driver version: 0, Library version: 0
    USB Cable Driver version: 7.1.8.0
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
    Checking path: \Products\RH-112\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.100
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.10il
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh1120_nai03.10il
    Changing flashing settings...
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.10mr
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh1120_nai03.10mr
    Setting local mode...
    Reading IMEI...
    Reading IMEI data...
    IMEI data corrupt...
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.100
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
    Flash ID is 0x28882000
    Loader size is 0x4B38; Loader chk: df
    Loader is ready...
    MSID: 845151BBB7F7C27B8801497B43
    MSID decoded: 3E4EBAE900951CB4A8000000
    FAID: FD0EE58DBE0D06DC91C94AB9
    Erasing...
    Found 5 interval(s) to erase
    Operation took 1 minutes 11 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 16 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.10mr
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 84A8104B3785084DF4DC7F9097
    MSID decoded: 3E4EBAE900951CB4AA000000
    FAID: AEAE1449708B4CDCFB4A62E0
    Erasing PPM...
    Found 2 interval(s) to erase
    Operation took 0 minutes 24 seconds...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh1120_nai03.10mr
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Operation took 0 minutes 13 seconds...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 52 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-112, Software version: 03.10
    IMEI: 358261034005716
    Product Code: 0593282
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Done!
    Done!
    Powering the phone...
    Unlocking...
    ASIC: b
    SW version: 03.10
    Unlock not supported!
    Failed! Aborting!
    Done!
  2. ( quangminh900 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    hoangsonnd (20-11-2009)
  1. Unlock Nokia 1202 VinaPhone
    By AnNam_Mobile in forum DCT4 - WD2
    Bài viết cuối: 14-11-2010, 08:58
  2. Trả lời: 29
    Bài viết cuối: 29-08-2010, 11:21
  3. Trả lời: 0
    Bài viết cuối: 19-07-2010, 08:52
  4. unlock 1202 chưa đến 5s
    By truongchinhvy in forum Phần mềm và các mã lệnh cho Nokia
    Trả lời: 47
    Bài viết cuối: 24-06-2010, 09:05
  5. MXKEY - First in the world REAL unlock for Nokia 1202, 1661, 1662, 5030
    By TUYHOAGSM™ in forum MX-KEY (by Alim Hape)
    Trả lời: 19
    Bài viết cuối: 12-04-2010, 23:36
