Kết quả 1 tới 4 của 4
    Thành viên tích cực mr.kent's Avatar
    Mặc định 3110 ko chạy đc
    các anh xem dùm em cái log. ko hỉu sao em chạy ko dc nữa
    JAF version 1.98.62
    Detected PKEY: 9000AAC9
    Card life counter: 99.99%
    Detected version: 01.B1, Driver version: 0, Library version: 0
    USB Cable Driver version: Can't read USB Cable Driver version!
    Detected P-KEY: 9000AAC9
    Changing mode...Done!
    Fast phone flashing selected.
    Fast phone flashing disabled.
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.mcusw
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_v
    Languages in ppm: English,Chinese T,Vietnamese
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_v
    Backing up CRT data...
    Setting FLASH MODE
    Loader version: 01.10.02 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 89810089 <=> INTEL -> Type not in database
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\UFS\RAP3Gv3_algo_fps8.fg
    Loader version: 01.0C.05 -> Revision: 0000
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Reading CMT NPC certificate...
    NPC crt not available...
    Reading CMT VARIANT certificate...
    VARIANT CRT not available...
    Reading CMT CCC certificate...
    CCC not available...
    Reading CMT HWC certificate...
    HWC not available...
    Saved to C:\Program Files\ODEON\JAF\ProgData\12345678901234_CRT_backup _42311.rpl
    Backup CRT OK!
    Backing up SIMLOCK data...
    Setting local mode...
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\351963030154987_CRT_backu p_42311.pm
    Done!
    Backup LCK OK!
    Manual mode selected, version can't be checked!
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101001101
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 222001112E317E565C206568916582BBE32EFBB1
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    ROM ID: 191EC665DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\UFS\rap3gv3_2nd.fg
    CMT Boot Ready
    CMT Loader Ready
    Operation took 0 minutes 6 seconds...
    Sending CRT data...
    Error in RD cmd...
    Error preparing flashing...
    học, học nữa,học mãi....hộc máu !!!
    V.I.P HUE_GSM's Avatar
    Mar 2008
    Đến từ Huế city.
    Error in RD cmd...
    Lổi của bạn là lỗi ic flash,bạn nên đóng lại đi,chúc may mắn.
    Jul 2007
    Bạn vệ sinh tiếp xúc cáp, cáp. check áp cấp cho flash trước khi gỡ flash nhé!
    MinhTuong Mobile Service Center.
    V.I.P trantamweb™'s Avatar
    Mar 2008
    Bro nói rõ xem tình trạng máy bị sao.Mất nguồn hay còn nguồn.Nếu còn nguồn thì kiểm tra lại cable ,vệ sinh lại tiếp xúc.Nếu máy mất nguồn thì hỏi khách xem rơi hay tự dưng mất nguồn.Nếu tự dưng mất nguồn thì Bro lấy cái Cable USB ra Flash bằng Dead USB xem ao.Kinh nghiệm bản thân em thấy Flash dead USB cũng khá hay , cứu máy cũng good nhất là trường hợp Cable cùi mía.Hoặc nếu có HWK mang qua đó quất cũng Ok.Chúc thành công.
    Best regard
    Trantamweb : 0987.24.02.90 - 0975.19.09.90 - 0946.27.1234
  1. 3110 báo hạn chế dt cần giúp.
    By nguyenthi in forum BB5
    Trả lời: 22
    Bài viết cuối: 07-02-2012, 15:13
  2. 3110 chập nguồn cần giúp
    By PHÁT TÀI in forum BB5
    Bài viết cuối: 05-12-2011, 15:08
  3. Xin Giúp 3110 chạy contactservice
    By teoduagang in forum Phần mềm và các mã lệnh cho Nokia
    Trả lời: 20
    Bài viết cuối: 14-03-2010, 17:53
  4. Trả lời: 22
    Bài viết cuối: 16-09-2009, 14:31
