    Vi phạm nội quy kienvn762003's Avatar
    Mặc định 7100s Cần giúp đỡ
    Mình mới nhận một cây 7100s mất nguồn bây giờ làm lên nguồn rùi mà cứ gọi được một lúc là mấy nguồn , mình đã làm u lash ic nguồn rùi , đưa vào jaf thì nó báo như vậy .
    MCU Flash file: C:\Program Files\Nokia\Phoenix\products\rm438__06.31.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\products\rm438__06.31.ppm_v
    CNT Flash file: C:\Program Files\Nokia\Phoenix\products\rm438__06.31.image_v
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    WARNING! Update your Pkey to increase life counter!
    Setting local mode...
    Reading IMEI...
    Reading IMEI data...
    Building RPL backup file...
    C:\Program Files\ODEON\JAF\ProgData\353217031640298_imei_back up_10342511.rpl
    Done!
    Backup imei OK!
    MCU: C:\Program Files\Nokia\Phoenix\products\rm438__06.31.mcusw
    Booting phone...
    MCU ID: 0x3168
    Boot size is 0x09A8
    Boot is ready...
    FLASH ID0: 883C0020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
    FLASH ID1: 883C0020 <=> ST -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 11
    First 16 bytes: AD 7E B6 1B 23 10 03 40 C6 05 E4 01 20 A2 00 00
    Flash ID is 0x3C882000
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
    Loader size is 0x5548; Loader chk: fe
    Loader is ready...
    MSID: 84E59342A10B854DD359428D06
    MSID decoded: 2C40BAE900012819A8000000
    FAID: 25CFE0C1D8A81A074DA98A89
    Operation took 0 minutes 9 seconds...
    Erasing...
    Found 2 interval(s) to erase
    Erasing area: 01020000 - 01C1FFFF...
    Operation took 1 minutes 50 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 1 minutes 12 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\products\rm438__06.31.image_v
    Booting phone...
    MCU ID: 0xFFFF
    This MCU ID is not supported in chosen flash file...
    Error booting phone...
    Có huynh nào biết xin chỉ dùm mình với
    sao không có ai giúp mình vậy ?
    Thành viên mới transy's Avatar
    Mar 2007
    Nếu muốn chạy lại thì kiếm cọng cáp khác thử xem, chạy 7100s trên jaf chưa thử, bạn mang qua mt chạy cho nó OK rồi tính tiếp, jaf giờ là chuối lắm, mấy dòng sau này nó support có được nữa đâu do nó out rồi.
    ok xin cảm ơn transy nhiều nghe để mình chạy thử bãng họp khác thữ coi
    V.I.P jerrylevu's Avatar
    Jun 2005
    sài gòn
    Update pkey của bạn đi rồi chạy lại thử .
    đâu có pkay của mình vẫn bình thường mà bạn
    Jun 2005
    sài gòn
    Trích Được post bởi kienvn762003 Xem bài viết
    pkey của bạn còn bao nhiêu card life counter , thì update cho nó lên 99% rồi chạy lại ,
    Thành viên chính thức thanhbinhcamau's Avatar
    Oct 2009
    qua nbox múc cái cho nó ngọt ngào nha người a e
    Điều 1 vợ luôn luôn đúng
    Điều 2 niếu thấy vợ sai nên nhớ lại điều 1
    xin cảm ơn mọi người nhiều
  1. 7100s cần ae giúp....
    By sang_apple in forum BB5
    Bài viết cuối: 01-06-2012, 17:49
  2. 7100s-2 cần giúp đỡ.
    By thaomy13072008 in forum BB5
    Bài viết cuối: 15-05-2011, 12:00
  3. 7100s sọc màn hình xin giúp
    By nguyenlammobile in forum DCT4 - WD2
    Bài viết cuối: 02-01-2011, 11:59
  4. 7100s xin giúp
    Bài viết cuối: 29-12-2010, 15:27
  5. 7100s xin giúp
    By chucuongthinh in forum DCT4 - WD2
    Bài viết cuối: 16-10-2009, 22:39
