Kết quả 1 tới 10 của 12
    Thành viên chính thức vungtau's Avatar
    Mặc định 3110c cứu gấp
    các ae xem giùm em cái log máy rơt nước em đã tám sạch sẽ rồi
    đã làm chân 2 con nguồn rồi
    nhưng nó chỉ lên sang đứng im thôi
    ae ai đã làm qua sin chỉ giáo
    thanks anh em
    Getting MCU ID
    Phone didn't answer with TX line high after power on!
    Causes:
    1. Phone don't power on -> Check cable
    2. TX pin from phone don't make contact -> Check cable
    3. UPP damaged -> change UPP
    MCU ID: 0xAAAA
    Failed! Aborting!
    Done!
    Phone Restarted...
    Changing mode...Done!
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101001101
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 1B000203A14E70564CD8899E9D033080DD60D9AD
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    ROM ID: 191EC665DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
    Loader version: 01.1E.00 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 881C0020 <=> ST -> M39L0R807
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
    Loader version: 01.21.01 -> Revision: 0000
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    Fast phone flashing selected.
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-237\
    Checking path: \Products\RM-237\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_s
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_s
    Languages in ppm: English,Bahasa Indonesia,Bahasa Malasia
    Changing flashing settings...
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_v
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_v
    Languages in ppm: English,Chinese T,Vietnamese
    Backing up CRT data...
    Setting FLASH MODE
    CMT Boot Ready
    CMT Loader Ready
    Reading CMT NPC certificate...
    Reading CMT VARIANT certificate...
    VARIANT CRT empty, skip save...
    Reading CMT CCC certificate...
    Reading CMT HWC certificate...
    Saved to C:\Program Files\ODEON\JAF\ProgData\35308102681185_CRT_backup _1352511.rpl
    Backup CRT OK!
    Backing up SIMLOCK data...
    Setting local mode...
    Failed! Aborting!
    Failed to backup LCK...
    Manual mode selected, version can't be checked!
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Sending CRT data...
    No convertion block detected or file already converted.
    Erasing...
    Operation took 0 minutes 59 seconds...
    Writing...
    Stage 1
    Sending CMT HASH for NOLO
    Sending CMT HASH for KEYS
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for PASUBTOC
    Sending CMT PUB KEYS...
    Sending CMT HASH for UPDAPP
    Sending CMT HASH for DSP0
    Sending CMT HASH for MCUSW
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Sending CRT data...
    Stage 1
    Sending CMT HASH for PMM_CONF
    Sending CMT HASH for SBIF_CONF
    FAST MODE finish!
    Operation took 2 minutes 6 seconds...
    Reseting phone...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_v
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Erasing...
    Operation took 0 minutes 19 seconds...
    Writing...
    Stage 1
    Operation took 0 minutes 36 seconds...
    Reseting phone...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_v
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Erasing...
    Operation took 0 minutes 49 seconds...
    Writing...
    Writing converted flash to 128k page
    Operation took 0 minutes 39 seconds...
    Reseting phone...
    Done!
    Total time: 5 Minutes, 46 Seconds
    DCT4/BB5 counter: 1454
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Vi phạm nội quy kienvn762003's Avatar
    bạn phải tìm file cao hơn rùi chạy lại đi
    Thành viên tích cực nguyenchithan01's Avatar
    máy bị mất nguồn hay bị gì vậy ban.thử cáp khác xem
    V.I.P jerrylevu's Avatar
    Jun 2005
    sài gòn
    Kiếm cọng cáp khác , vệ sinh kỹ tiếp cáp trên bo
    Causes:
    MCU ID: 0xAAAA
    Máy chưa nhận mà .
    Thành viên tích cực thamngocphong's Avatar
    kim lên như vậy thì kiếm tra con retu làm đã kĩ chưa ? cáp mà tốt rồi thì bạn thử thay retu khác đi ..bệnh này báo như vậy kohan83 là cáp đâu ...chúc thành công
    em đã chạy lai 7.21 rồi mà vẫn vạy
    con này em nó bị tắm nước
    em đã làm 2 con nguồn lớn nhỏ rồi chạy lại nó vẩn thế
    Trích Được post bởi vungtau Xem bài viết
    kẹp dòng kim nguồn lên như thế nào bạn ? lên cao bao nhiu ? bạn cho thêm thông tin đi
    Trích Được post bởi thamngocphong Xem bài viết
    nó lên 0,2v thôi anh
    thế này nhé ..tình trang kim lên o.2v mà dừng lại ko xuông thì máy đã bị chạm ..để bít dc chạm nguồn hay cpu thì bạn gỡ bỏ con retu ra ngoài ròi kẹp guồn thử coi kim còn lên ko . nếu kim vẫn còn lên thì loại bỏ chạm nretu kiểm tra tiếp con tavoh (là nguôn nhỏ đó ) hoặc bạn kẹp nguồng và tăng dòng lên một xí ..rồi coi con nào nóng thì múc con đó nha ..chúc thành công
    Thành viên mới minh_thanh's Avatar
    Dec 2008
    check lại cáp đi nếu cáp ok thì xem lại con cpu
  1. LOG 3110c bi loi
    By huynhsoldtdd in forum BB5
    Bài viết cuối: 22-02-2011, 09:16
  2. 3110c không đồng bộ được
    By thanhcongvl86 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 19-02-2011, 15:33
  3. Trả lời: 6
    Bài viết cuối: 09-12-2010, 14:26
  4. 3110c cap cuu
    By VŨ PRO in forum BB5
    Bài viết cuối: 29-07-2009, 12:59
  5. 3110c cap cuu
    By phuonganhmobile in forum BB5
    Bài viết cuối: 29-07-2009, 11:51
