Kết quả 1 tới 10 của 12
    V.I.P tôn tẩn's Avatar
    A HÙNG VÙNG 7 NÚI
    Mặc định Xem log dùm e
    Getting MCU ID
    MCU ID: 0x2051
    FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: 001000EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9
    FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
    FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 03.88
    28-Jul-06
    RM-72
    GSM P1.1
    (c) NMP.
    HW version: 6001
    PCI version:
    UEM version: 400
    UPP version: 8273
    RFIC version: p
    10ff11ff0205
    DSP version: p
    B0446T_05w14
    LCD version: SHARP
    PPM version: V 03.70
    09-Jan-06
    RM72_73_-
    GSM P1.
    V
    BT MCM version: SW-V:03.48
    ADSP version: TIKU_PB_04w47_06_w01
    Production serial number: MYG182682
    Product code: 0522117
    Module code: 0202552
    Basic production code: 0519797
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 357964002368906
    IMEI spare to net: 3A 75 69 04 20 63 98 00
    IMEI SV to net: 33 75 69 04 20 63 98 20 F4
    Master Code: 7110512150
    Phone type: RM-72, Software version: 03.88, Language Pack: V
    User code: 12345
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-72.ini
    Setting local mode...
    Reading product code...
    Product Code: 0522117
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-72\
    Scanning for ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.880
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.88V
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.88.ucp_V
    Languages in ppm: English,Vietnamese,Chinese S,Chinese T
    Done!
    A HÙNG VÙNG 7 NÚI
    6230i của e lúc có sóng lúc mất e chay máy báo như vậy đó nhờ mấy a chỉ e với
    Thành viên mới foreverlovech's Avatar
    Jan 2007
    Sw:erase,full flash,write pm good.Hw:tìm mạng.nếu không tìm được mạng:lỗi thu.xem angtenswich,lọc thu,trung tần.thu được nhưng không đăng kí được mạng gốc:mất phát.xem angtenswich,lọc phát;trung tần,công suât.còn vẫn không ok bạn có thể đóng lại uem!good luck!
    A HÙNG VÙNG 7 NÚI
    Bị mất nguồn chek được mà info k dược là bị j mấy ace xin cám ơn
    Thành viên mới 0984367600's Avatar
    Trích Được post bởi bannguyen Xem bài viết
    tấy nhiên là vẫn check dươc chứ bạn bạn thử chạy lại xem sao
    Jan 2007
    Ban hỏi gì mà chẳng có đầu có đuôi gì cả.không hiểu gì.mất nguồn thì làm sao info được chứ.flash lại xem báo gì.6230 hay con khác
    A HÙNG VÙNG 7 NÚI
    Getting MCU ID
    MCU ID: 0x2051
    Algo is ready...
    Done!
    Phone Restarted...
    Setting test mode...
    Setting FULL FACTORY...
    Done!
    INI file .ini is missing. Continue searching for second ini type...
    Changing flashing settings...
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.88A
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.88.ucp_A
    Languages in ppm: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.88T
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.88.ucp_PH
    Languages in ppm: English,Vietnamese,Tagalog,Chinese S,Chinese T
    MCU: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.880
    Booting phone...
    MCU ID: 0x2051
    BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia
    Boot size is 0x2398
    Boot is ready...
    Flash ID is 0x22E800EC
    Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia
    Loader size is 0x84A0; Loader chk: 4c
    Loader is ready...
    MSID: 84D27A5C7731217763E21F3DF2
    MSID decoded: 91DFBAE9005174EBA8000000
    FAID: 923733E7E1859CFEF2CE9140
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 00000000 - 0000FFFF...
    Erasing area: 00010000 - 009FFFFF...
    Erasing area: 00A00000 - 00B3FFFF...
    Erasing area: 00B60000 - 00FAFFFF...
    Operation took 1 minutes 37 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 1 minutes 0 seconds...
    Restarting MCU...
    NAND Format OK!
    CNT: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.88.ucp_PH
    Booting phone...
    MCU ID: 0x2051
    Boot size is 0x2398
    Boot is ready...
    Flash loader is C:\Program Files\ODEON\JAF\Flash\te_essr.fia
    Loader size is 0x9858; Loader chk: b3
    Loader is ready...
    Operation took 0 minutes 9 seconds...
    Erasing Content Pack...
    Mass Memory Device Detected...
    MM Bus Configured...
    Formating MM...Format failed!
    A HÙNG VÙNG 7 NÚI
    đấy e flash lại như thế đó giúp mình với 6230i a ah
    Jan 2007
    bạn xoá sau đó chạy lại đi.chọn file ppm và cnt đuôi v và ucp_v gì đó bạn nhé.sửa sóng cơ mà làm gì mà lại mất nguồn.không được xem lại những gì bạn vừa làm
    A HÙNG VÙNG 7 NÚI
    Mình muốn xóa full thì làm sao hả mấy a mình k bít xóa full ai có video cho mình xin với
  1. Trả lời: 5
    Bài viết cuối: 08-05-2014, 10:25
  2. anh em check dùm con ip 5 dùm nhà mạng nào
    By NHẬTMINH_GSM in forum iPHONE 5 - 5s
    Bài viết cuối: 26-10-2013, 09:55
  3. Anh em xem dùm con 6085 bus check bị lỗi gì dùm em với
    By hunglangtu_qb in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 23-08-2013, 09:11
  4. Xin a/e check dùm con 3gs và tư vấn dùm e
    By keylove779 in forum iPHONE 3Gs
    Bài viết cuối: 03-08-2013, 11:47
  5. Mấy anh xem dùm log n-gate qd dùm
    By minhkhoa_iphone in forum DCT4 - WD2
    Bài viết cuối: 14-12-2009, 14:42
