    Thành viên chính thức hoangtuechxxi's Avatar
    Mặc định Xem giúp em cái log
    Getting MCU ID
    MCU ID: 0x0120
    FLASH ID0: 7E250100 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    FLASH ID1: 01000000 <=> Flash -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 06.20
    16-04-03
    NHM-7
    (c) NMP.
    HW version: 0900
    PCI version:
    UEM version: 8
    UPP version: 288
    RFIC version: 0105
    DSP version: G5.0-5.50
    PPM version: V 06.20
    16-04-03
    NHM-7
    (c) NMP.
    S
    Production serial number: CNC178333
    Product code: 0506685
    Module code:
    Basic production code: 0503666
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 351104401821942
    IMEI spare to net: 3A 15 01 44 10 28 91 04
    IMEI SV to net: 33 15 01 44 10 28 91 54 F2
    PDC: 4E 54 54 4A 50 12 34 56
    Master Code: 0645621736
    Phone type: NHM-7, Software version: 06.20, Language Pack: S
    User code: 12345
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_NHM-7.ini
    Checking path: C:\Program Files\Nokia\Phoenix\Products\\
    Checking path: \Products\\
    No ini files found...
    Done!
    LÊN NGUÔN VÀI PHÚT TREO MÁY RỒI TẮT NGUÔN.MONG ANH EM CHI GIÁO
    Thành viên mới mailoc421979's Avatar
    bạn xóa full nạp lại nếu ko hết là phải đục đẽo rối đó bạn !
    NHẬN MÁY----ĐỤC MÁY-----CHẾT MÁY-----ĐỀN MÁY----NÂNG CAO TAY NGHỀ---HỀ HỀ HỀ.
    V.I.P HUE_GSM's Avatar
    Mar 2008
    Đến từ Huế city.
    Vệ sinh cáp rồi chạy lại ver cao nhất,nếu không được bạn xem lại con CPU ,chúc may mắn.
    máy bạn là máy gì mà ko thấy viết vậy
    Yahoo: chuonggc02@yahoo.com
    Thành viên mới ngọc_yến_mobile's Avatar
    love
    MCU ID: 0x0120
    cái này có bị flat không ạ
    may em là 8310.ai co vẻ cao nhất cho em xin luôn ah!thanks nhiều
    Aug 2008
    Trích Được post bởi ngọc_yến_mobile Xem bài viết
    MCU ID: 0x0120
    Ko đâu Bà Nội
    Anh Minh Mobile
    32-Hoàng Diệu-Eakar-Dak Lak
    em chay lai ver 6.20 ma vẫn z
    Se0 hem aj help mjnh hjt zj?
