    Thành viên mới tha0m0bile's Avatar
    Mặc định Nokia 1202 xin giúp đỡ.
    máy mất nguồn em thay cpu rùi chay lai nói báo như này:
    MCU ID: 0x2293
    First 16 bytes: 00 20 88 28 00 01 01 21 00 20 88 28 00 01 01 FF
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    MCU Flash file: C:\Documents and Settings\Administrator\Desktop\1\rh112_003.000
    Phone Type:
    MCU Flash file: C:\Documents and Settings\Administrator\Desktop\1202 RH-112 v.3.10\rh112_003.100
    Phone Type:
    PPM Flash file: C:\Documents and Settings\Administrator\Desktop\1202 RH-112 v.3.10\rh112_003.10el
    Phone Type:
    CNT Flash file: C:\Documents and Settings\Administrator\Desktop\1202 RH-112 v.3.10\rh1120_nai03.10el
    MCU: C:\Documents and Settings\Administrator\Desktop\1202 RH-112 v.3.10\rh112_003.100
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x28882000
    Loader size is 0x4B38; Loader chk: dd
    Loader is ready...
    MSID: 8440887B628F9C7CAAC06180EE
    MSID decoded: 3E4EBAE9008D3652A8000000
    FAID: 207802417249A3B75BB0DF9B
    Operation took 0 minutes 13 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Operation took 1 minutes 7 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: C:\Documents and Settings\Administrator\Desktop\1202 RH-112 v.3.10\rh112_003.10el
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 8488A6B7AF2AADA141398B3AD1
    MSID decoded: 3E4EBAE9008D3652AA000000
    FAID: A39881EC2A4AD05B92A6E0CF
    Erasing PPM...
    Found 2 interval(s) to erase
    Operation took 0 minutes 22 seconds...
    Writing...
    Operation took 0 minutes 6 seconds...
    Restarting MCU...
    CNT: C:\Documents and Settings\Administrator\Desktop\1202 RH-112 v.3.10\rh1120_nai03.10el
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 26 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Powering the phone...
    Failed! Aborting!
    Init phone communication...
    Failed!!!
    các huynh ai làm rùi gúp em vs. thank all
    Thành viên chính thức kimchinsu_hn's Avatar
    Feb 2010
    thế thì chịu thôi
    Đồng Nai
    thử xóa full chạy lại xem sao.........
    TUI KO CÓ TỘI SAO BẮC TUI.......KÝ....
    YAHOO:van_ninh_mobile
    ĐÔ LƯƠNG _ NGHỆ AN
    thay thử cpu 1200 sang xem thế nào bạn chạy lại pm => pm full => unlock => Factory. chúc thành công
    Thành viên kỳ cựu TẤN PHÚC's Avatar
    long an
    bạn thử thay con cpu khác xem sau, và dùng hwk chạy là ok nhất
    ĐTDĐ TẤN PHÚC LONG AN hotline 0986.58.78.79
    AGRIBANK 6607205041502 - CN Tân Thạnh-Long An- CTK Trần Văn Niềm
    Chuyên Sữa: Điện Thoại ,Unlock. Chạy phần mềm, nạp Tiếng Việt
    Bắc Hòa-Tân Thạnh-Long An
    Aug 2008
    Trích Được post bởi van_ninh_mobile Xem bài viết
    U2293 xóa rồi lấy cái gì Unlock bạn
    Thay U 2292 vô rồi chạy lại
    Anh Minh Mobile
    32-Hoàng Diệu-Eakar-Dak Lak
  1. nokia 1202 cần anh em giúp
    By nguyenngocthanh19841984 in forum DCT4 - WD2
    Bài viết cuối: 14-03-2014, 20:20
  2. nokia 1202 xin ae giúp đỡ
    By huphuc_mobile209 in forum DCT4 - WD2
    Bài viết cuối: 01-07-2012, 13:13
  3. nokia 1202 xin giúp đở
    Bài viết cuối: 27-05-2012, 18:33
  4. nokia 1202 cần giúp !
    By vovuongvu85 in forum DCT4 - WD2
    Trả lời: 14
    Bài viết cuối: 25-05-2011, 10:35
  5. Nokia 1202 cần giúp đỡ.
    By quyettam in forum DCT4 - WD2
    Bài viết cuối: 10-03-2010, 19:38
