Kết quả 1 tới 3 của 3
    V.I.P QuangNinhGSM's Avatar
    Mặc định 7070xin chỉ giúp
    Power on the phone...
    FAILED...
    Powering the phone...
    Failed! Aborting!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-116\
    Checking path: \Products\RH-116\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-116\rh116__06.82.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-116\rh116__06.82.ppm_aa
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-116\rh116__06.82.image_aa
    Languages in ppm: English,Dannish,Norwegian,Swedish
    Changing flashing settings...
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-116\rh116__06.82.ppm_v
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-116\rh116__06.82.image_v
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-116\rh116__06.82.mcusw
    Booting phone...
    MCU ID: 0x3162
    Boot size is 0x09A8
    Boot is ready...
    FLASH ID0: 883C0020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
    FLASH ID1: 883C0020 <=> ST -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 11
    First 16 bytes: AD 7E B6 1B 00 FF 10 40 00 00 00 00 00 00 00 00
    Flash ID is 0x3C882000
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
    Loader size is 0x5548; Loader chk: fe
    Loader is ready...
    MSID: 84A6E9020A1B28E3E635086F35
    MSID decoded: 2C40BAE900D09D59AA000000
    FAID: F65E105B61BD45D5E4C741C9
    Erasing...
    Found 2 interval(s) to erase
    Erasing area: 01020000 - 01C3FFFF...
    Operation took 1 minutes 48 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 59 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-116\rh116__06.82.image_v
    Booting phone...
    MCU ID: 0x3162
    Boot size is 0x09A8
    Boot is ready...
    File is already converted to 128k page...
    Loader is ready...
    MSID: 84F47D7C689BB47A4772B0C128
    MSID decoded: D26EBAF100D09D59AA000610
    FAID: 6810353A14153B534A61168A
    Erasing Content Pack...
    Erasing area: 02000000 - 02DBFFFF...
    Erasing area: 02DC0000 - 02F9FFFF...
    Operation took 4 minutes 37 seconds...
    Writing...
    Operation took 0 minutes 28 seconds...
    Restarting MCU...
    Extracting Content Pack...
    Running: (c) Nokia File Server
    CNT Extract OK.
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-116\rh116__06.82.ppm_v
    Booting phone...
    MCU ID: 0x3162
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 84284DDCA8C4A43BE172B2536F
    MSID decoded: 3E4EBAE900D09D59AA000000
    FAID: C9111A33A54E65667C9EF69B
    Erasing PPM...
    Found 1 interval(s) to erase
    Erasing area: 01C40000 - 01FFFFFF...
    Operation took 0 minutes 33 seconds...
    Writing...
    Operation took 0 minutes 19 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 9 minutes 17 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-116, Software version: 06.82
    IMEI: 356626000768319
    Product Code: 0557778
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Done!
    Done!
    Unlocking...
    ASIC: b
    SW version: 06.82
    Stoping...
    Setting local mode...
    Reading imei...
    IMEI/ESN: 356626000768319
    Reseting warranty data...
    Reseting LifeTimer...
    Done!!!
    Done!
    Unlocking...
    ASIC: b
    SW version: 06.82
    Stoping...
    Unlocking...
    ASIC: b
    SW version: 06.82
    Selected flash file: C:\Program Files\Nokia\Phoenix\Products\RH-116\rh116__06.82.mcusw
    Decrypting flash...Done
    Checking ROM call...Done
    Checking security function...Done
    Encrypting....Done
    Patch status: 00
    MCU ID: 0x3162
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing area: 01080000 - 0109FFFF...
    Failed! Aborting!
    unlok ko được mấy huynh ơi
    ko có anh em nào giúp à
    Jan 2009
    Check cáp, ko được anh mang sang HWK hoặc MTBox làm lại ok liền anh ơi
