Kết quả 1 tới 10 của 16
    Thành viên kỳ cựu duyquang_mobile's Avatar
    Oct 2009
    Mặc định xem giúp em voi
    Getting MCU ID
    MCU ID: 0x1120
    FLASH ID0: F822EC00 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    FLASH ID1: 01000000 <=> Flash -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Failed! Aborting!
    Setting local mode...
    Failed! Aborting!
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.020
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.02md
    Languages in ppm: English,Filipino,Vietnamase
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.020
    Booting phone...
    MCU ID: 0x1120
    Boot size is 0x09A0
    Boot is ready...
    Flash ID is 0xF822EC00
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: f0
    Loader is ready...
    MSID: 844EE8622247B3008032D6F77D
    MSID decoded: 3E4EBAE9001E5F0DAA000000
    FAID: 3846C3D415C5FCDF64A76BD2
    Operation took 0 minutes 15 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013BFFFF...
    Erasing area: 013C0000 - 013EFFFF...
    Operation took 0 minutes 40 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.02md
    Booting phone...
    MCU ID: 0x1120
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 011E0000 - 011EFFFF...
    Erasing area: 011F0000 - 0137FFFF...
    Operation took 0 minutes 16 seconds...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 23 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    em mới nên chưa biết nhiều xin các ah chỉ giúp em với
    SỐNG TRÊN ĐỜI PHẢI CÓ CHỮ TÂM . DTDD :0922972486
    MUỐN THÀNH CÔNG PHẢI CÓ CHỮ NHẪN.... yahoo nguyenquang_201086
    Oct 2009
    xem giup em voi
    V.I.P HUE_GSM's Avatar
    Mar 2008
    Đến từ Huế city.
    kiếm cộng cáp khác flash lại cái xem sao bạn.
    Jan 2009
    Nguyên nhân lúc đầu thế nào bạn, bị gì mà bạn chạy lại vậy, check cáp tốt ko được thì làm chân con UPP
    Oct 2009
    tting MCU ID
    MCU ID: 0x1120
    Algo is ready...
    Done!
    Phone Restarted...
    Failed! Aborting!
    Phone Type:
    Phone Type:
    Failed! Aborting!
    Booting phone...
    MCU ID: 0x1120
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing...
    Writing...
    Restarting MCU...
    Booting phone...
    MCU ID: 0x1120
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 22 seconds...
    Failed! Aborting!
    Oct 2009
    ah ơi em chạy lại vân bị nè giúp em với
    Oct 2009
    check được nhưng lại ko info được .máy bị mất sóng ah ạ
    Aug 2008
    Trích Được post bởi duyquang_mobile Xem bài viết
    Máy mất nguồn làm sao mà Info đc
    1 : Thiếu file CTN
    2 : Chỉnh vào chế độ Local Mode
    3 : đến cái đoạn waiting for to boot phone........ nếu cảm thấy khó boot thì ấn nút nguồn.
    Anh Minh Mobile
    32-Hoàng Diệu-Eakar-Dak Lak
    Oct 2009
    Getting MCU ID
    MCU ID: 0x1120
    Failed! Aborting!
    Done!
    Phone Restarted...
    Unpacking in C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07
    Please wait...
    Done unpacking nfp file...Selecting files...
    No header file found...Aborting!
    Phone Type:
    Phone Type:
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh930_nai7.02md
    Failed! Aborting!
    Booting phone...
    MCU ID: 0x1120
    Boot size is 0x09A0
    Boot is ready...
    Error in CHK...
    Error Loading loader!
    Oct 2009
    em đã thay cáp và chạy lại rùi mà vẫn ko được
