anh em xem hộ cái log em info lỗi gì mà mất nguồn vậy
Getting MCU ID
MCU ID: 0x2293
First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 03.00
14-11-08
RH-112
(c) NMP
HW version: 1000
PCI version:
UEM version: 1328
UPP version: 8851
RFIC version: 0700
DSP version: ICPR81_08w31_UPP
LCD version: UNKWN: IDs:
00:ff:00
PPM version: V 03.00
14-11-08
RH-112
(c) NMP
MD
ADSP SW version: V 03.00\n14-11-08\nRH-112\n(c) NMP\nmd
Production serial number: HBE135380
Product code: 0562205
Module code: 0203762
Basic production code: 0558505
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 358015035839808
IMEI spare to net: 3A 85 10 05 53 38 89 00
IMEI SV to net: 33 85 10 05 53 38 89 10 F4
Master Code: 7574007036
Phone type: RH-112, Software version: 03.00, Language Pack: MD
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-112.ini
Setting local mode...
Reading product code...
Product Code: 0562205
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
Checking path: \Products\RH-112\
No ini files found...
Done!
