MCU SW version: V 07.21
05-11-08
RM-237
(c) Nokia.
HW version: 2000
PCI version:
RFIC version: 17211721
DSP version:
ICPR61_08w10
PPM version: V 07.21
05-11-08
RM-237
(c) Nokia.
V
Retu version: 32
Tahvo version: 53
Content Pack version: Content: v
V 07.21
05-11-08
RM-237
(c) Nokia.
Production serial number: 7F0852094
Product code: 0514949
Module code: 0203291
Basic production code: 0542523
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 356974012792517
IMEI spare to net: 3A 65 79 04 21 97 52 01
IMEI SV to net: 33 65 79 04 21 97 52 21 F5
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-237.ini
Setting local mode...
Reading product code...
Product Code: 0514949
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-237\
Checking path: \Products\RM-237\
No ini files found...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Done!
máy luc đầu mất nguồn em thay cặp upp và flash chạy lại lên nguồn nhưng máy hát nhạc chút là mất nguồn và sạt vô chút cũng mất nguồn nữa.có cách nào fix dc lỗi này ko mấy anh em có mt_box.
			 xem dùm em cái log 3110c
