em có con 1661.2 em máy rớt nước. chết ic nguồn ,em thay ic. đỗ log .rồi .em chạy lại fần mềm .có ime. đầy đủ .mà sao o .unlok. đuợc .em chạy trên Jaf.chạy xong nó báo
MCU ID: 0x2293
FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\\
Checking path: \Products\\
No ini files found...
Phone Type:
MCU Flash file: D:\FAI NOKIA. CUA BUNG\rh122\1661 RH-122_3.70\rh122_003.700
Phone Type:
PPM Flash file: D:\FAI NOKIA. CUA BUNG\rh122\1661 RH-122_3.70\rh122_003.70mr
MCU: D:\FAI NOKIA. CUA BUNG\rh122\1661 RH-122_3.70\rh122_003.700
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Flash ID is 0xC0882000
Loader size is 0x4B38; Loader chk: 47
Loader is ready...
MSID: 84FF1CFFDE9F82BF7ED5C5C476
MSID decoded: 3E4EBAE90060254AA9000000
FAID: 2DFD66B0C20F97B6201022A3
Erasing...
Found 4 interval(s) to erase
Erasing area: 01010000 - 0179FFFF...
Erasing area: 017A0000 - 017EFFFF...
Erasing area: 01F00000 - 01FDFFFF...
Operation took 1 minutes 41 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 15 seconds...
Restarting MCU...
PPM: D:\FAI NOKIA. CUA BUNG\rh122\1661 RH-122_3.70\rh122_003.70mr
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84B5092D117C122EFD59B77F8A
MSID decoded: 3E4EBAE90060254AAA000000
FAID: 0A274211F774AA0BD187D6BB
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01250000 - 0125FFFF...
Erasing area: 01260000 - 0174FFFF...
Operation took 1 minutes 3 seconds...
Writing...
Operation took 0 minutes 17 seconds...
Restarting MCU...
Flashing Done!
Operation took 3 minutes 36 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-122, Software version: 03.70
IMEI: 354198039296292
Product Code:
Resetting PPC...
Done!
Powering the phone...
Unlocking...
ASIC: b
SW version: 03.70
Unlock not supported!
Failed! Aborting!
như vay .các bác chỉ giùm em với em cảm ơn các bác nhiều .![]()
