Kết quả 1 tới 10 của 15
    Thành viên tích cực duong le's Avatar
    Mặc định xin hỏi 7610?
    mình nhận máy 7610 mở nguồn lên sáng màn hình rồi tắt lại mình chạy phần mềm thì báo:
    Card life counter: 99.99%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\
    Scanning for ini files...
    INI file .ini is missing. Continue searching for second ini type...
    Changing flashing settings...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.02
    Languages in ppm: English,French,German (Euro A)
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\products\RH-51\RH51_52_67_68PE706420.C1
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\products\RH-51\RH51PE706420.01
    Languages in ppm: English,German,French (France)
    Setting local mode...
    Reading IMEI...
    Reading IMEI data...
    Building RPL backup file...
    C:\Program Files\ODEON\JAF\ProgData\355382000710742_imei_back up_11351512.rpl
    Done!
    Backup imei OK!
    MCU: C:\Program Files\Nokia\Phoenix\products\RH-51\RH51_52_67_68PE706420.C1
    Booting phone...
    MCU ID: 0x1081
    BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia
    Boot size is 0x10D8
    Boot is ready...
    FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
    FLASH ID2: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
    FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
    Flash ID is 0x22F800EC
    Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia
    Loader size is 0x7F10; Loader chk: ac
    Loader is ready...
    MSID: 845E3B40BC79739BE86586E6DE
    MSID decoded: 3E4EBAF70042CC9AA9000000
    FAID: BD98E1B3CB4109FDD2F6426E
    Operation took 0 minutes 16 seconds...
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 00000000 - 0000FFFF...
    Erasing area: 00010000 - 00FFFFFF...
    Erasing area: 02000000 - 0287FFFF...
    Erasing area: 02FC0000 - 02FEFFFF...
    Operation took 3 minutes 41 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 3 minutes 5 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\products\RH-51\RH51PE706420.01
    Booting phone...
    MCU ID: 0x1081
    Boot size is 0x10D8
    Boot is ready...
    Loader is ready...
    Operation took 0 minutes 17 seconds...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 02A00000 - 02C9FFFF...
    Operation took 0 minutes 24 seconds...
    Writing...
    Operation took 0 minutes 20 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 8 minutes 10 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-51, Software version: 7.0642.0
    IMEI: 355382000710742
    Product Code: 0514543
    Resetting PPC...
    Done!
    nhưng máy vẫn vậy cá bạn à .mình đã làm cpu ,ic nguồn vẫn vậy ,bạn nào gặp qua chỉ mình với mình cảm ơn!
    quocchuong566
    Guest quocchuong566's Avatar
    chạy song nhớ format. nếu not ok thì câu bsi cho nó;
    bạn chỉ rõ hơn được không ? cảm ơn bạn
    quocchuong566
    Trích Được post bởi duong le Xem bài viết
    mình nói vậy bạn không hiểu sao, qua yahoo nói rõ hơn
    Thành viên chính thức tuonglammobile's Avatar
    Oct 2009
    bạn đo lại đường bsi có đứt ko ?
    CÙNG NHAU HỌC HỎI_CÙNG NHAU TIẾN BỘ
    V.I.P tôn tẩn's Avatar
    A HÙNG VÙNG 7 NÚI
    thử pin khác đi pac ơi coi bị pin đó
    mình đã thay pin khác thay thử ic nguồn khác vẫn vậy , đo đường BSI không bị đứt bạn à
    quocchuong566
    không đứt nhưng lâu ngày con đó die, câu như hình mình cho
    Đồng Nai
    bác làm lash chưa nhỉ.
    cau theo hình bạn cho vẫn không được bạn à
  1. cần sơ đồ 7610
    By duylam in forum DCT4 - WD2
    Bài viết cuối: 06-12-2010, 23:05
