Kết quả 1 tới 2 của 2
    Thành viên danh dự TuấnPhát_GSM's Avatar
    Jan 2009
    Lightbulb MXKEY - Major update
    MXKEY · v3.3 revision 1.0, Public-Release
    Major update
    MAIN
    Improved,Application Signing system
    - client time will be checked before signatures generation to avoid duplicate error request.
    - date-time issue bug on server side fixed.
    - no messages will be displayed if signatures invalid when working in FREE module (siemens).
    Added,Server status info on server check
    - ping check removed, so there will be no more firewall problem.
    Redesigned, Modules Manager page
    - This will make the possibility to update single module at future updates.
    Check for daily update re-enabled.
    - application will check update once a day and will be displayed in tooltips when new update found.
    NK
    - Added BB5 RAPIDO STN8815(N96) usb flashing(Dead Usb also possible)
    - Fixed DCT4PLUS ASIC 0x3168 patch unlock and imei changes (2630 v52.70,2680 v06,80)
    - Fixed BB5 Flashing (partitioning bug)
    - Fixed Fast flashing bug when using JAF box.
    - Added PM308 1 backup on 'BB5 SW downgrade fix'
    Other modules recompiled for major api changes.
    Please 'Sign Application' first,make sure you have correct date,time setting on your computer.
    Every card have 5 chances to request digital signature from server.
    DOWNLOAD HERE
    sao nó cứ update mãi và liên tục vậy nhỉ ,thằng MX-KEY này chắc không thọ được lâu hay sao ấy
    HỌC CHO RỘNG ,HỎI CHO KỸ; SUY NGHĨ CHO THẬT RÕ RÀNG
    LÀM VIỆC CHO HẾT SỨC ; NHƯ THẾ MỚI THÀNH NGƯỜI
  1. Major 1.50 Firmware Update
    By HoangThong_hotrokythuat5 in forum GPGDragon
    Bài viết cuối: 13-12-2010, 11:46
  2. MXKEY - Major Update - ATF (Advance Turbo Flasher) Interface added
    By trantamweb™ in forum MX-KEY (by Alim Hape)
    Bài viết cuối: 15-06-2010, 23:25
  3. ALCATEL - MOTOROLA update (27 / 04 / 2010)- MAJOR UPDATE !!!!
    By HoangThong_hotrokythuat4 in forum Easy Unlocker
    Bài viết cuối: 28-04-2010, 08:42
  4. Genie Major Update - 18 Jan 2010
    By hungphongmobile™ in forum Genie Universal
    Bài viết cuối: 18-01-2010, 23:40
