Kết quả 1 tới 10 của 10
    Thành viên chính thức tin ht's Avatar
    Mặc định 1650 loi pm
    em mới nhận cây 1650 kẹp nguồn kim dao động như lên nguồn. đã xoá full nạp pm máy báo như thế này! mong anh em giúp đỡ!!!thank
    Getting MCU ID
    MCU ID: 0x2292
    FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    Backup IMEI zone...
    Setting local mode...
    Failed! Aborting!
    Getting MCUID...
    MCU ID: 0x2292
    Reading flash chip detailes...
    MCU ID: 0x2292
    Boot is ready...
    Algo is ready...
    Loader is ready...
    Erasing area: 01000000 - 01FFFFFF...
    Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_05.320
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_05.32mq
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm3050_nai5.32mq
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_05.320
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Flash ID is 0xC0882000
    Loader size is 0x4B38; Loader chk: 47
    Loader is ready...
    MSID: 840A049048E1782C4970D46CD0
    MSID decoded: 3E4EBAE900C7BD40A8000000
    FAID: AFCF8E8296DA166CCD02B89A
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 01010000 - 0179FFFF...
    Erasing area: 017A0000 - 017EFFFF...
    Erasing area: 01F00000 - 01FDFFFF...
    Operation took 1 minutes 37 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_05.32mq
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 84D7E34853E61F9ADE99F83DF4
    MSID decoded: 3E4EBAE900C7BD40AA000000
    FAID: C70373018216BE392390FD5F
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 01240000 - 0125FFFF...
    Erasing area: 01260000 - 0175FFFF...
    Operation took 1 minutes 3 seconds...
    Writing...
    Operation took 0 minutes 18 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm3050_nai5.32mq
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 84C812851579518BC5223551DC
    MSID decoded: 3E4EBAE900C7BD40A9000000
    FAID: E0540DD4AD972CBD3452FEE4
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01760000 - 0179FFFF...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 4 minutes 10 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    đã thử mấy file rồi ma vẫn thế. máy ko bị rơi. các huynh có cao kiến xin chỉ giáo
    Đất Hà Thành!
    bịt chân vpp rùi chạy lại coi bạn!
    Thành viên chính thức hiephiep's Avatar
    Jan 2007
    ban dưa qua hwk chay nha ,hok may coi doi~ cap khac thử xem
    Thành viên tích cực htqs1619's Avatar
    đúng đó đưa qua nbox thử xem sao bạn
    Võ Hoàng Trung 5307205011919 Agribank TX Gia Nghĩa
    Đt:0979.003.789 or 0987.265.267
    Thành viên chính thức thuanloitelecom's Avatar
    Máy dòng này thì thấy chạy bên HWK chuẩn hơn đó bạn à
    đã bit chân đó rồi ma vẫn thế.mình chỉ có jaf va ufs thôi. theo cac huynh có khả năng lỗi lash ko??
    Thành viên tích cực duyquan's Avatar
    Jan 2008
    em cũng dính 1 con i trang vậy.sàng qua main khác mà lại ok luôn. pó tay.
    :p Để tiền trong túi làm chi .....? :p
    :DMua liều thuốc chuột , phòng khi chán đời :(
    để minh tử xem,thanhk
    Thành viên tích cực thenghiep's Avatar
    che chân vpp lại rùi mà vẫn thế thì thay cho nó sợi cáp tốt khác rùi chạy lại xem sao
    dt : 0988.756.436 : 086.253.01.04
    hợp tác cùng phát triển
  1. MobiMB v3.5.3.9 Reloaded (Unofficial) for Nokia 1200, 1202/03, 1650, 1650, 1661
    By TUYHOAGSM™ in forum Chương trình cài hình nhạc cho các lọai ĐTDĐ
    Bài viết cuối: 27-10-2010, 09:37
  2. 1650 không sạc được
    By cuongmobile.vn in forum DCT4 - WD2
    Bài viết cuối: 16-01-2010, 20:21
  3. 1650 nháy màn
    By HTC_DVV78 in forum DCT4 - WD2
    Trả lời: 17
    Bài viết cuối: 02-01-2009, 09:18
  4. 1650 help
    By trung83 in forum DCT4 - WD2
    Bài viết cuối: 05-10-2008, 12:58
