Mình mới mua MXkey , lấy 1200 bình thường chạy thử . chạy xong nó báo CS , lấy JAF đập lại thì OK .
Đây là log MXkey :
Using device: J.A.F, FW ver: 01.B1
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38
UEM ID: 00CEA4E0A3BDA66
ASIC type: 11
UEM Imei: 35196103819525
Processing file: rh99_05.910 as MCU
[DCT4,DCT4 ALGORITHM] size: 2.27 MB
Supported Ids: 2292
UEM ID: 00CEA4E0:2984DA60
Area [01000000-0100FFFF] erased in 1.125 s
Area [01010000-013AFFFF] erased in 1 min 2.735 s
Area [013B0000-013EFFFF] erased in 4.328 s
Area [017C0000-017EFFFF] erased in 0.047 s
Area [01FC0000-01FEFFFF] erased in 0.047 s
Flash programming ...
Programming completed in 14.359 s
File Processed in 1 min 34.266 s
Formating FS: FILE2 ...
Processing file: rh990_nai5.91mr as CNT
[DCT4,DCT4 ALGORITHM] size: 110.59 KB
Supported Ids: 2292
Area [01380000-013AFFFF] erased in 3.203 s
Programming completed in 0.844 s
Extracting Content Pack, File Server fake reply for CUI phone.
Content Pack extracted successfully in 0.031 s
File Processed in 23.172 s
Processing file: rh99_05.91mr as PPM
[DCT4,DCT4 ALGORITHM] size: 1.13 MB
Supported Ids: 2292
Area [01240000-0124FFFF] erased in 1.094 s
Area [01250000-0137FFFF] erased in 20.485 s
Programming completed in 7.328 s
File Processed in 40.516 s
Flashing completed in 3 min 18.313 s
Phone Type: RH-99
SW Version: V 5.91 27-03-09 RH-99 (c) NMP
Imei plain: 35196103819525-9
Product Code: 0546885
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: MR
Language Pack:
- not available.
Imei net: 35196103819525
Counter: 0/3, 0/10
CONFIG_DATA: 0000000000000000
PROFILE_BITS: 0000000000010000
SIMLOCK_DATA corrupted!
Total time to process is 3 min 25.625 s
CÁM ƠN ACE giúp đỡ , nguyên nhân để khắc phục cho MX key
