    Thành viên mới namckpt's Avatar
    Dec 2008
    Mặc định 7260 chết nguồn cần các huynh xem giúp
    Getting MCU ID
    MCU ID: 0x1130
    FLASH ID0: 88260020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 05.90
    09-05-06
    RM-17
    (c) Nokia.
    PCI version:
    UEM version: 400
    UPP version: 4400
    RFIC version: 0205
    DSP version: P05w06.v34
    LCD version: AMAZON
    PPM version: V 05.90
    09-05-06
    RM-17
    (c) Nokia.
    T
    Production serial number:
    Product code:
    Module code:
    Basic production code:
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 354334002547466
    IMEI spare to net: 3A 45 33 04 20 45 47 06
    IMEI SV to net: 33 45 33 04 20 45 47 16 F9
    Master Code: 2460062465
    Phone type: RM-17, Software version: 05.90, Language Pack: T
    User code: 12345
    Block 1:
    Lock 1: CLOSED -> Lock Data: 00101F
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-17.ini
    Setting local mode...
    Reading product code...
    Product Code:
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-17\
    Scanning for ini files...
    INI file .ini is missing. Continue searching for second ini type...
    Checking path: \Products\RM-17\
    No ini files found...
    CNT Flash file: rm17__05.90.image_?
    Done!
    Backup IMEI zone...
    Reading IMEI...
    Reading IMEI data...
    Building RPL backup file...
    C:\Program Files\ODEON\JAF\ProgData\354334002547466_imei_back up_16372712.rpl
    Done!
    Getting MCUID...
    MCU ID: 0x1130
    Reading flash chip detailes...
    MCU ID: 0x1130
    Boot is ready...
    Algo is ready...
    Loader is ready...
    Erasing area: 01000000 - 01FFFFFF...
    Done!
    Changing flashing settings...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__05.900
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__05.90c
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__05.90.image_c
    Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__05.90t
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__05.90.image_optus
    Languages in ppm: English,Vietnamese,Tagalog,Chinese S,Chinese T
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__05.900
    Booting phone...
    MCU ID: 0x1130
    Boot size is 0x09A0
    Boot is ready...
    First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Flash ID is 0x26882000
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_st_i.fia
    Loader size is 0x4B28; Loader chk: 35
    Loader is ready...
    MSID: 844FE8FE4B28D5F44A4E9871B5
    MSID decoded: 2C40BAE90087A374AA000000
    FAID: 2A6A1DA4033BD7E74A759BA0
    Erasing...
    Found 3 interval(s) to erase
    Erasing area: 01020000 - 0181FFFF...
    Erasing area: 01E60000 - 01FDFFFF...
    Operation took 1 minutes 15 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 50 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__05.90.image_optus
    Booting phone...
    MCU ID: 0x1130
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 8493E1CBC401E147DD3DE727F6
    MSID decoded: 1C15BAE30087A374AD0005BD
    FAID: F914995299C7F8B3B6514A00
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01A40000 - 01E5FFFF...
    Operation took 0 minutes 32 seconds...
    Writing...
    Restarting MCU...
    Extracting Content Pack...
    Running: (c) Nokia File Server
    CNT Extract Skiped.
    PPM: C:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__05.90t
    Booting phone...
    MCU ID: 0x1130
    Boot size is 0x09A0
    Boot is ready...
    Loader size is 0x4B28; Loader chk: d5
    Loader is ready...
    MSID: 8496FAEF5A1C40D6B9533DB27C
    MSID decoded: 3E4EBAE90087A374A9000000
    FAID: 29BD72EA9E8E16C52050AB09
    Erasing PPM...
    Erasing area: 01820000 - 01A3FFFF...
    Operation took 0 minutes 17 seconds...
    Writing...
    Operation took 0 minutes 9 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 4 minutes 15 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    IMEI: 354334002547466
    Product Code:
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Done!
    Done!
    Done!
    chạy lại bằng Jaf máy báo như trên mà cho kẹp dòng đồng hồ chỉ nhíc lên 1 tẹo rùi lại về 0.mong các huynh chỉ giùm.
    Đồng Nai
    máy lúc đầu bị gì bác .
    Thành viên tích cực samhue_and_aus's Avatar
    Trích Được post bởi van_ninh_mobile Xem bài viết
    hình như ban đầu chủ thớt nói là mất nguồn
    CRAZY FAN R:DCK:METALLICA,U2, LINKIN PARK AND GREENDAY!!!
    Dec 2008
    lúc bị chết nguồn.em chạy lại thấy check được info cũng được mà cho vao kẹp dòng không lên.mấy bác xem dùm
    Jan 2009
    anh làm mấy con trở gần công tắc nguồn, ko đủ áp kick nguồn cũng gây nên hiện tượng này đó
  6. ( Hà Linh Mobile™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    namckpt (28-12-2009)
    Dec 2008
    em đã thay rùi mà không được .các anh có cách nào khác giúp em với
    Dec 2008
    em làm được rùi cám ơn mấy anh đã quan tâm
  9. #8
    Jan 2009
    Nói cho anh em biết, bạn đã làm những gì mà thành công, đó là hình thức xây dựng diễn đàn đó anh
  10. #9
    Thành viên tích cực BUIVANCHUNG's Avatar
    Kim Anh Mobile Đồng Nai
    ông này spam rồi,máy log ok chỉ có lên nguồn thôi mà thử anh em để thư giản sao.....
  1. Trả lời: 3
    Bài viết cuối: 10-02-2010, 14:12
  2. Trả lời: 12
    Bài viết cuối: 14-02-2009, 23:59
  3. Trả lời: 3
    Bài viết cuối: 17-12-2008, 09:26
  4. Trả lời: 11
    Bài viết cuối: 15-11-2008, 21:24
