    Thành viên mới hoanghai_kh4's Avatar
    Dec 2009
    Mặc định xin mọi người xem em cái log với ah
    đây là log info
    MCU ID: 0x1201
    FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 6.40
    12-01-07
    RH-93
    (c) NMP
    HW version: 0526
    PCI version:
    UEM version: 1328
    UPP version: 4609
    RFIC version: 0500
    DSP version: P05w06.v34
    LCD version: WIN:MYKS:01
    ST7506
    PPM version: V 6.40
    12-01-07
    RH-93
    (c) NMP
    MD
    ADSP SW version: V 6.40\n12-01-07\nRH-93\n(c) NMP\nmd
    Production serial number: IEF315626
    Product code: 0537102
    Module code: 0203169
    Basic production code: 0536354
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO: s?????????????????????????????????????????????????
    Default SN type: s?????????????????????????????????????????????????
    IMEI plain: 359368001790763
    IMEI spare to net: 3A 95 63 08 10 97 70 06
    IMEI SV to net: 33 95 63 08 10 97 70 36 F5
    Master Code: 2773066167
    Phone type: RH-93, Software version: 6.40, Language Pack: MD
    User code: ÿ#
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-93.ini
    Checking path: C:\Program Files\Nokia\Phoenix\Products\\
    Checking path: \Products\\
    No ini files found...
    Done!
    Jan 2009
    Log đẹp anh ạ, anh cho biết máy bị gì mới nói rõ và có cách giải quyết được
    Dec 2009
    Dạ máy 1110i.máy bị bệnh khó khởi động.em đã chạy.ver khác.write pm+factory+unlock.em thấy chỏ này lạ quá e không hiểu Product specific data:
    Long production SN:
    Default SN type: s????????????????????????????????????????????????? .
    xin mọi người chỉ giúp ah.thanks các anh.
    TP.Tuy Hòa
    theo như bạn nói thì con này khả năng hỏng UEM rất cao
    bạn thay lại UEM rồi gửi file chắc hết bệnh
    Thành viên tích cực tien1989's Avatar
    nếu thay uem thì thay lun flash đi khỏi gửi file thay cả đôi chạy lại ok lụm lúa
    ai chơi võ lâm 2 pmmmmmmm
    Dec 2009
    vâng để em làm rồi báo cáo các bác sau ah.
    Dec 2009
    thanks mọi người đã quan tâm.em đã làm ok.thay thach anh.
