First of all, happy new year to all of our customers.
New Cyclone Installer v1.03 is ready (final installer, no bulk updates needed).
Installer v1.03
02.01.2010
- Added new BB5 Unlock,Relock,Autolock,Repair Method by RPL Generation, this uses server and consumes 10 logs whilst your credits amount must be > 100.
- Supported are ALL PA_SL2 Phones, both RAPv3 and RAPIDO, with following hashes:
9A28E119033B91D14D22838C86D0D53C
9DDBFCFE6E73CED7D8C6268C8EB85723
38F312750F686F9FC9B1B3778774A195
BAF3A9C3DBFA8454937DB77F2B8852B1
CAEEBB65D3C48E6DC73B49DC5063A2EE
F2D76DFAFD66C7F195F278417DF05888
F682624FFB08F6D955DBE7D9C0485084
FCB5C510AF7F09F313D9BDE85A707CC0
- Before unlock software will ask you (when possible) if you want RPL calculation. If you don't need unlocking by RPL, simply click NO and old free unlocking methods will be used (PM308+120 recalc, Secure RAM dump and NCK calc on RAPIDO PA_SL2 phones, etc). However there are some phones which might be unlocked only using new method (9DDB - 3600,5220,7310, or new 5800 >v.30, new N96, etc)
- After unlock, requested RPL file will be saved to STORED FILES dir, it might be used later after phone chip erase, etc - as a generic backup
- To Autolock/Relock use "Import SL5" function and point to SL5 array file in "UnlockData" dir, with SW comes few generated files
- If you need SL5 file for your network, use "Create SL5" button and enter MCC-MNC, SL5 file will be generated for you and your phone might be relocked
- SL Area might be repaired using UNLOCK button for SL2 phones
- RPL Write bugs fixed ("simlock not accepted" after few tries)
- Path "/" problem fixed
- Memory manager updated to v4.94
- New skin manager introduced (6.53) - removed flash files selection bugs
- GUI redesigned a bit
- Nokia Connectivity Cable Driver updated to v7.1.22
- 2760h RM-391 v06.83 Unlock / Relock added
- 2330c RM-512 v09.55 Unlock / Relock added
- 2330c-b RM-513 v09.55 Unlock / Relock added
- 2720f RM-519 v08.42 Unlock / Relock added
- 2720f-b RM-519 v08.42 Unlock / Relock added
- 2720f RM-519 v09.55 Unlock / Relock added
- 2720f-b RM-519 v09.55 Unlock / Relock added
- SX4 Bypass during BB5 Unlock removed, is no needed anymore
- Fixed USB stack hanging up on some Windows configuration due to invalid hexcodes in BoardCode Revision USB Field
- After Super DCT4 Activation in Credits tab box Security Page is automaticlly upgraded, no need doing it manually
- New firmware v01.15 introduced - box can switch itself from MAIN mode to BOOT mode (no USB reconnect needed anymore)
- 6220c,3600s booting fixed in new firmware
- New Secure bootloader v02.10 introduced
- New bootloader supports more types of smartcards (autobaud, PTS protocol negotiation, etc)
- Secure BootAgent v1.00 introduced in new firmware
- Firmware RTOS Code Updated to v6.0.1
- Slightly code optimizations and stability improvments in new firmware
- Secure Bootloader upgrade introduced after box maintenance
- Added support for Cyclone box HW REV A116, A117, A118, A119, A11A, A11B, A11C
Here is example phones unlocked by new RPL Method,
5800 SW v31.x:
Code:
BB5 Unlock Started...
MCU Version V ICPR72_09w20.8
MCU Date 09-07-09
Product RM-356
Manufacturer (c) Nokia
IMEI 353205037049770
Mastercode 323571474
Simlock Server SIMLOCK SERVER
Simlock Key 2600300000000000
Simlock Profile 8000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 26003F
Reading Security Block...
Security block OK!
Determining PA Simlock...
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 16900018F3740052C3ECA61A74BBE7E9A3A34FCE
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_ROM_ID: 4B9B75103E691FF8
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND
FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
Determined PA Simlock: PA_SL2
Checking for Rootkey Hash support and selecting Unlock Method...
Selected Unlock Method: RPL Calculation
Booting RAP...
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
Receiving RPL from Server...
Cyclone Server (1.0.0.549), Cyclone Box Team 2008, 2009, 2010 - Ready.
Disconnected from Cyclone Server
Credits Left: 880
Saving RPL File to "RM-356_353205037049770_2010-01-02_015618.Unlock.RPL"
Writing Simlock...
Simlock ACCEPTED OK !
MCU Date 09-07-09
Product RM-356
Simlock Key 2440700000000000
Simlock Profile 0000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Unlock finished!E51:
Code:
MCU Version V ICPR71_08w44.4
MCU Date 11-12-08
Product RM-244
IMEI 357663016552576
Mastercode 152622740
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK!
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103
CMT_PUBLIC_ID: 0E60010930850058EEBC00CD174EE90CEB054FF0
CMT_ROM_ID: A8C1D6713E691FF8
FlashChip[0,CMT]: 0x00EC004000600022, Samsung, ONENAND
Box VPP disabled
PAPUBKEYS Hash for CMT: 35AC54F8E31BE1357AB78D73834F020906331653
Restarting MCU...
Booting RAP...
Cyclone Server (1.0.0.552), Cyclone Box Team 2008, 2009, 2010 - Ready.
Credits Left: 830
Saving RPL File to "RM-244_357663016552576_2010-01-02_051510.Unlock.RPL"
Writing Simlock...
MCU Date 11-12-08
Product RM-244
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Unlock finished!Download Link: http://rapidshare.com/files
Download Link: http://rapidshare.com/files/32908443...xInstaller.exe
! BOX FIRMWARE UPDATE IS NEEDED TO USE LATEST UPDATE !
Best Regards,
Cyclone Team
(stay tuned.... in January )
			 ** Cyclone Shot, "SL3" Unlock and more... **
