Kết quả 1 tới 10 của 21
    Thành viên chính thức ducthanhmobile's Avatar
    Aug 2008
    Mặc định 1110i đọc tin nhắn mất nguồn ! LOG !!!!
    JAF version 1.98.61
    Detected PKEY: 90028AC1
    Card life counter: 52.27%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112
    USB Cable Driver version: 7.0.2.0
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-93\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02qa
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02qa
    Languages in ppm: English,Chinese S,Chinese T
    Changing flashing settings...
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02ma
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02ma
    Languages in ppm: English,Chinese S,Chinese T,Vietnamese,Filipino
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    First 16 bytes: AD 7E A6 1A 0B BE 0B E2 6D 58 6B E4 CB EE 65 14
    Flash ID is 0x72888900
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia
    Loader size is 0x5538; Loader chk: bb
    Loader is ready...
    MSID: 84AD60D5685EA3DAF10B267981
    MSID decoded: 3E4EBAE9001815E8AA000000
    FAID: BEF38300CCE0CCAC5E85BDBA
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013BFFFF...
    Erasing area: 013C0000 - 013EFFFF...
    Operation took 0 minutes 33 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 15 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02ma
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    First 16 bytes: AD 3A 22 08 01 0A 0A 62 49 08 09 C4 41 0E 25 14
    Loader is ready...
    MSID: 84E1C9F5A4D0A013EFBB7CD30F
    MSID decoded: 3E4EBAE9001815E8A9000000
    FAID: 1215AA3F0D4805E9B5865DBD
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 011E0000 - 011EFFFF...
    Erasing area: 011F0000 - 0137FFFF...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02ma
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01380000 - 013BFFFF...
    Operation took 0 minutes 2 seconds...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 1 minutes 50 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    chỉ em với !!!
    Thành viên tích cực DUY_GSM's Avatar
    krongpac_daklak
    xóa full chạy lại write pm khác nhé
    Jan 2009
    Anh chạy file md đi. Chọn ver thấp thôi ver 6.40 là vừa.
    Đồng Nai
    xóa full nạp lại ,kiếm cáp nào thơm tí nha bác.......
    TUI KO CÓ TỘI SAO BẮC TUI.......KÝ....
    YAHOO:van_ninh_mobile
    Aug 2008
    MCU ID: 0x2201
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    Powering the phone...
    Unlocking...
    IMEI: ???????????????
    ASIC: 2
    SW version: 7.02
    Selected flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
    Decrypting flash...
    Encrypting....
    CHK Patch found - Unlock Patch found and are not in same block
    Patch status: 01
    MCU ID: 0x2201
    Algo is ready...
    Erasing area: 01140000 - 0115FFFF...
    Unlocking...
    Simlock data rejected! Code: 0x13
    Failed! Aborting!
    em chạy FULL nhưng đến unlock thì thế này đây
    Thành viên tích cực ngocminh_dtdd's Avatar
    thegioimobile
    imel của anh đâu rồi sao mà imel đẹp thế anh ,đi toi rồi
    Aug 2008
    bây giờ lắp sim vào thì báo sim not valid ! thế có nghĩa là sao hả các anh ?
    thegioimobile
    Trích Được post bởi ducthanhmobile Xem bài viết
    anh ơi 1110i mà mất imel là nó bị như thế đó ,kiếm cái log khác chạy lại imel đi you.ai có thì xin log,không thì mua cùng lắm 20k thôi mà.
    V.I.P UNLOCKDTDD's Avatar
    tìm ver khác nạp cho nó đi bạn , tặng cho nó một cái pm nưa nhé bạn hiền
    thegioimobile
    Trích Được post bởi QUYNHCHAU 02 Xem bài viết
    mât imel rồi thì chạy lại ver cao nhất và PM chuẩn nhất cũng thế thôi you ah
  1. 1110i không nhận sim
    By xecgayhiep in forum DCT4 - WD2
    Trả lời: 24
    Bài viết cuối: 12-08-2011, 21:50
  2. máy 1110i màn hình nhấp nháy
    By minhtuyen in forum DCT4 - WD2
    Trả lời: 15
    Bài viết cuối: 30-07-2011, 13:25
  3. Cách gửi tin nhắn làm cho 1200 . 1110i sập nguồn
    By nhatnam19041992 in forum DCT4 - WD2
    Trả lời: 20
    Bài viết cuối: 29-03-2010, 07:43
  4. 1110i ko nhận sim
    By duylam in forum DCT4 - WD2
    Bài viết cuối: 07-07-2008, 16:28
  5. 1110i nhận một mạng???
    By vietcuong1211 in forum DCT4 - WD2
    Bài viết cuối: 31-03-2007, 16:09
