Getting MCU ID
MCU ID: 0x2201
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 6.40
12-01-07
RH-93
(c) NMP
HW version: 0501
PCI version:
UEM version: 2336
UPP version: 8705
RFIC version: 0500
DSP version: P05w06.v34
LCD version: INLX:MYKSv03
ST7506
PPM version: V 6.40
12-01-07
RH-93
(c) NMP
MD
ADSP SW version: no NAI version
Production serial number: VF0400516
Product code: 0529665
Module code: 0202589
Basic production code: 0520758
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 357060000307267
IMEI spare to net: 3A 75 60 00 00 03 27 06
IMEI SV to net: 33 75 60 00 00 03 27 36 F5
Master Code: 0043222106
Phone type: RH-93, Software version: 6.40, Language Pack: MD
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-93.ini
Setting local mode...
Reading product code...
Product Code: 0529665
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
Checking path: \Products\RH-93\
No ini files found...
Done!
Phone Type:
MCU Flash file: d:\My Documents\Downloads\Compressed\1110i RH-93_7.02\rh93_07.020
Phone Type:
PPM Flash file: d:\My Documents\Downloads\Compressed\1110i RH-93_7.02\rh93_07.02md
Phone Type:
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: d:\My Documents\Downloads\Compressed\1110i RH-93_7.02\rh93_07.020
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_st_i.fia
Loader size is 0x4B28; Loader chk: cb
Loader is ready...
MSID: 84E048BFE7302898DD3CD84305
MSID decoded: 3E4EBAE900020834AA000000
FAID: 323620B2462BFF7C43BF9E31
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013BFFFF...
Erasing area: 013C0000 - 013EFFFF...
Operation took 0 minutes 33 seconds...
Writing...
Perm. Data Restore OK
Restarting MCU...
PPM: d:\My Documents\Downloads\Compressed\1110i RH-93_7.02\rh93_07.02md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 011E0000 - 011EFFFF...
Erasing area: 011F0000 - 0137FFFF...
Operation took 0 minutes 13 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 1 minutes 30 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-93, Software version: 7.02
IMEI: 357060000307267
Resetting PPC...
Unlocking...
ASIC: 2
SW version: 7.02
Selected flash file: d:\My Documents\Downloads\Compressed\1110i RH-93_7.02\rh93_07.020
Decrypting flash...
Encrypting....
CHK Patch found - Unlock Patch found and are not in same block
Patch status: 01
MCU ID: 0x2201
Algo is ready...
Erasing area: 01140000 - 0115FFFF...
Unlocking...
Checking locks...
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
MCU ID: 0x2201
Algo is ready...
Done!
DCT4 unlock counter: 9
Done!
Setting test mode...
Setting FULL FACTORY...
Done!
Done!
			 1110i cần anh em xem cái log chạy ver cao rồi mà vẫn lên noikia khởi động lien tục
 Được post bởi manh long
