E VỪA MỚI NHẬN CÂY 1208 LÚC TRƯỚC BỊ RƠI NƯỚC VS SẠCH LÊN NGUỒN SÀI BÌNH THƯỜNG,NHƯNG JO LẠI MẤT NGUỒN.KẸP NGUỒN VÀO KIM DÒNG LÊN 2 RÙI DỰC DỰC KO RỚI.NHƯNG KO KẸP CHẤU PSI THÌ KIM DÒNG LÊN 2 RÙI RỚT LIỀN.E MANG QUA N-BOX CHẠY DAO DIỆN J,A,F MÁY LÊN NGUỒN NHƯNG SÀI SÁNG CHIỀU THÌ LẠI Y NHƯ CỦ.E XÓA FLASH NẠP LẠI VẨN VẬY,E THAY IC NGUỒN GỞI LOG VẨN VẬY,E LÀM CHÂN FLASH LẠI VẨN VẬY,E ĐỐNG LẠI UPP VẨN VẬY.BÂY JO MÁY CHẠY LẠI THÌ LÊN NGUỒN BÌNH THƯỜNG KO VẤN ĐỀ J CẢ,NHƯNG SÀI SANG CHIỀU THÌ VẨN VẬY,AE NÀO CÓ TỪNG GẬP QUA PAL NÀY RÙI XIN CHỈ GIÁO THÊM,E CHẬN THÀNH CẢM ƠN,CÒN ĐÂY LÀ LOG CỦA E.MÔNG MẤY ACE XEM DÙM. Getting MCU ID
MCU ID: 0x2292
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
Checking path: \Products\RH-105\
No ini files found...
Phone Type:
MCU Flash file: D:\chuong trinh dien thoai\FILES FLASH\file flash nokia\pile lash tv\1208 RH-105_5.71\rh105_05.710
Phone Type:
PPM Flash file: D:\chuong trinh dien thoai\FILES FLASH\file flash nokia\pile lash tv\1208 RH-105_5.71\rh105_05.71mr
Setting local mode...
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: D:\chuong trinh dien thoai\FILES FLASH\file flash nokia\pile lash tv\1208 RH-105_5.71\rh105_05.710
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 845186E1D6A16E3608F554EC12
MSID decoded: 3E4EBAE900CB371FA8000000
FAID: 2F163BE0A3717F1CFF84254C
Erasing...
Found 5 interval(s) to erase
Operation took 1 minutes 21 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 15 seconds...
Restarting MCU...
PPM: D:\chuong trinh dien thoai\FILES FLASH\file flash nokia\pile lash tv\1208 RH-105_5.71\rh105_05.71mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing PPM...
Found 2 interval(s) to erase
Operation took 0 minutes 26 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 42 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-105, Software version: 5.71
IMEI: 356413021323956
Product Code: 0550577
Resetting PPC...
Done!
			 1208 nhờ ae giúp đở
 1208 nhờ ae giúp đở
