MÁY ĐẢ THAY UEM,LÀM LẠI UPP.FLASH GỞI LOG.XOA FLASH CHẠY LẠI,WD PM,UNLOCK.FATORY.NHƯNG SÀI DC SÁNG CHIỀU THÌ LẠI MẤT NGUỒN,KIM DAO ĐỘNG LÊN 2 Y NHƯ LÊN NGUỒN MÀ LÊN KO NỔI VẬY ĐÓ,ACE NÀO CO GẬP QUA RÙI XIN CHỈ GIÁO.E ĐẢ GỞ BỎ 2 CON TỤ BỰ GẦN R22 RÙI,MÔNG ACE NHIỆT TÌNH GIÚP ĐỞ.CÒN ĐÂY LÀ LOG. Getting MCU ID
MCU ID: 0x2292
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
Checking path: \Products\RH-105\
No ini files found...
Phone Type:
MCU Flash file: D:\chuong trinh dien thoai\FILES FLASH\file flash nokia\pile lash tv\1208 RH-105_5.71\rh105_05.710
Phone Type:
PPM Flash file: D:\chuong trinh dien thoai\FILES FLASH\file flash nokia\pile lash tv\1208 RH-105_5.71\rh105_05.71mr
MCU: D:\chuong trinh dien thoai\FILES FLASH\file flash nokia\pile lash tv\1208 RH-105_5.71\rh105_05.710
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 845186E1D6A16E3608F554EC12
MSID decoded: 3E4EBAE900CB371FA8000000
FAID: 2F163BE0A3717F1CFF84254C
Erasing...
Found 5 interval(s) to erase
Writing...
Perm. Data Restore OK
Operation took 0 minutes 16 seconds...
Restarting MCU...
PPM: D:\chuong trinh dien thoai\FILES FLASH\file flash nokia\pile lash tv\1208 RH-105_5.71\rh105_05.71mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing PPM...
Found 2 interval(s) to erase
Writing...
Restarting MCU...
Flashing Done!
Operation took 1 minutes 4 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-105, Software version: 5.71
IMEI: 356413021323956
Product Code: 0550577
Resetting PPC...
Error PPC reset!
Failed! Aborting!
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing...
Operation took 1 minutes 19 seconds...
Writing...
Restarting MCU...
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing PPM...
Operation took 0 minutes 26 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 37 seconds...
Reading...
Resetting PPC...
Done!
THANK ACE NHIỀU LẮM
			 Nhờ anh em  xem hộ dùm log Nokia 1208.
