    Thành viên chính thức tuandt2's Avatar
    Mar 2008
    Mặc định N2700c CONTACT SERVICE???
    Con 2700c khách mang vào nói là nó tự nhiên bị contact service. Em mang ra chạy phần mềm ok hết (kể cả FULL FACTORY. Máy vẫn vào được chế độ Local Mode và Test Mode) nhưng bật lên là bị Contact service. Đây là log của nó:
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
    USB Cable Driver version: 7.1.22.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 07.80
    18-08-09
    RM-561
    (c) Nokia
    HW version: 1000
    PCI version:
    RFIC version:  06540601
    DSP version:
    ICPR72_09w24
    LCD version: SEIKO
    PPM version: V 07.80
    18-08-09
    RM-561
    (c) Nokia
    V
    BT MCM version: 2222-143C
    Retu version: 16
    Tahvo version: 22
    Content Pack version: Content: v_black
    V 07.80
    18-08-09
    RM-561
    (c) Nokia
    Production serial number: DAR284839
    Product code: 0579808
    Module code: 0204245
    Basic production code: 0577212
    Flash code:
    Order number:
    Product specific data:
    Long production SN: 0
    ATO:
    Default SN type:
    IMEI plain: 356912033598703
    IMEI spare to net: 3A 65 19 02 33 95 78 00
    IMEI SV to net: 33 65 19 02 33 95 78 40 F4
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    PROVIDER KEY: 2440700000000000
    Provider: AT&T;U.S.A. (3650)
    Key Code count: 0, FBUS Code count: 0
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-561.ini
    Setting local mode...
    Reading product code...
    Product Code: 0579808
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-561\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-561\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-561\rm561__07.80.mcusw
    PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-561\rm561__07.80.ppm_v
    CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-561\rm561__07.80.image_v_blac
    Done!
    Anh em nào có cao kiến xin chỉ dẫn cách xử lý nó giùm em với. Xin chân thành cảm ơn!!!
    V.I.P NGA CUN's Avatar
    May 2007
    hà nội city
    nhìn vào cái log của bạn có vẻ ok! nếu có cai mx-ey thử check coi cái xem nào? trong trường hợp này thì bạn thử sx4 xem có ok không hay lại banh tành rồi! nói chung nếu trong tay mà chỉ có JAF thì bó tay luôn!
    HÙNG NGA-MOBILE
    Repair All boot sam sung 3G
    đ/c: 55-trần hưng đạo -thành phố ninh bình
    đt:0984048988-0303899721
    Thành viên tích cực huuthien's Avatar
    sx4 write pm cho nó xem sao nha bạn khoan đụng đến phần cứng nha
    V.I.P anpha72000's Avatar
    Jan 2007
    cái này nếu có cái mx-key như bác NGA-CUN nói thì scan nó 1 phát rồi post lên cho anh em chuẩn bệnh nào
    HOT HOT DỊCH VỤ KTD TEAM CHO ANH EM.SUPPORT HỖ TRỢ ANH EM 24/7
    www.kythuatdidong.com yahoo : anpha72000
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    đừng nghe những gì khách nới anh nhé
    rơi họ cũng bảo là đang sài bị đó anh.
    Thành viên mới baolam_1988's Avatar
    Mặc định xin giúp 2700 chay tiếng viêt bi contact sevice..
    MCU SW : V 09.95 02-04-10 RM-561 (c) Nokia
    PPM SW : V 09.95 02-04-10 RM-561 (c) Nokia V
    Prd.Code: 0579808
    Bpr.Code: 0577212
    Prod.Sn : DAR009649
    HW Vers : 1000
    EM VILMA: 16
    EM BETTY: 22
    RFIC Ver: 06540601
    DSP Vers: ICPR72_09w26
    LCD Type: SEIKO
    IMEI : 358283-03-839014-2
    SL Serv : SIMLOCK SERVER
    SL Conf : 000-00-00000000000
    SL Prof : 0141194A00000000
    SL Count: 00 00
    SL Data Corrupted
    Provider: Not Found
    mong ae giúp đõ
    Thành viên kỳ cựu setot_thoi's Avatar
    Sóc Trăng
    [QUOTE]
    Trích Được post bởi baolam_1988 Xem bài viết
    Prd.Code: 0579808
    lập TOPIC mới OK . ae sẽ giúp
    MẩnMobile .Y/H : Jimmyphong10
    Thành viên chính thức binhhiep's Avatar
    minh lam sao ma tin duoc khach ha ban . ban sem vo ngoai may co bi sao ko da ban
  1. c2-01 contact service
    By QuocDat_mobile in forum BB5
    Trả lời: 25
    Bài viết cuối: 08-04-2015, 10:49
  2. 1208 máy không bị contact service làm cho bị contact service
    By hoangkhoi2012_mobile in forum DCT4 - WD2
    Trả lời: 19
    Bài viết cuối: 30-09-2013, 08:28
  3. Trả lời: 9
    Bài viết cuối: 08-06-2013, 17:52
  4. x2-02 contact service
    By Tuấn Tân Trụ in forum BB5
    Bài viết cuối: 05-04-2013, 16:40
  5. x2-02 contact service
    By THIÊN UY™ in forum BB5
    Bài viết cuối: 22-03-2013, 10:18
