1600 chép ct, xoá flash vẫn bình thường
khi kẹp nguồn , bấm mỡ nguồn kim lên được 1 rồn rớt xuống 0,3 treo luôn,
mình kẹp 2 chân hay 3 chân đều bị vậy
mình đã thay u chạy ct lại vẫn bị vậy mong anh em giúp giùm
mình đã thay máy con điện rồi vẫn không lên, minh không gắn man hình vào. nó vẫn vậy, lick nomal no báo
etting MCU ID
MCU ID: 0x2201
FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 7.02
10-12-07
RH-64
(c) NMP
HW version: 0501
PCI version:
UEM version: 1328
UPP version: 8705
RFIC version: 0500
DSP version: P05w06.v34
LCD version: UNKWN: IDs:
00:ff:00
PPM version: V 7.02
10-12-07
RH-64
(c) NMP
AA
ADSP SW version: V 7.02\n10-12-07\nRH-64\n(c) NMP\naa
Production serial number: DMA784465
Product code: 0525157
Module code: 0202591
Basic production code: 0520754
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 358961016310709
IMEI spare to net: 3A 85 69 01 61 13 70 00
IMEI SV to net: 33 85 69 01 61 13 70 40 F5
Master Code: 1724041644
Phone type: RH-64, Software version: 7.02, Language Pack: AA
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-64.ini
Setting local mode...
Reading product code...
Product Code: 0525157
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-64\
Scanning for ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.020
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.02qb
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh640_nai7.02qb
Languages in ppm: English,Chinese S,Bahasa Mal
Done!
khi bầm nomal để cho nó lên nguồn thì nó báo vậy, test mod với local mod thì được
Changing mode...
Failed!!!
Changing mode...
Done!
Changing mode...
Failed!!!
+4 EXP
