Trang 1 của 8 1 2 3 4 5 6 7 8 CuốiCuối
Kết quả 1 tới 10 của 73
    Executive Administrator taihv™'s Avatar
    Nov 2006
    Hà Nội
    Mặc định HWK new update !!
    01-05-2007
    New Release
    Release Date: 30/04/2007
    The Official release is ready in our download area.
    WARNING !!!
    If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk.
    NOTE: IF YOU HAVE UPGRADED YOUR UFS + HWK SUCESSFUL WITH SUITE V3.0.4 - V3.0.4.2, THERE IS NO NEED TO USE THE CLIENT AGAIN IN THIS VERSION
    DCTxBB5 v2.0.5.0
    1. New BB5 products: RM-101,RM-188,RM-208,RM-260 (N92-2,6086,E65-1,6086b)
    2. New DCT4 products: RH-94,RH-95,RH-97,RH-98,RM-225.RM-229
    (1112,1112i,6060v,6061,6030b,6030)
    3. New CDMA products: RH-71,RH-77,RH-89,RM-121(2125,2126i,2118,2115i,2355)
    4. New CDMA TIKU products:
    RM-41,RM59,RM-60,RM61,RM-66,RM-124,RM-125,RM-154,RM-193
    (3155,3155i,6155,6235,6236i,3152,6265,6265i,2855,6 165,6275,2865)
    5. Support of new Flash update pack 7.4.13.26017, new Flash chips added.
    6. Improved F-Bus polling, fixed "Bad Resp UFSx" after fatal error.
    7. Improved diagnostics of "Dead APE" and not recognized Flash chips.
    8. Fixed "Patch" option bug.
    9. UDA(CP) flashing for RM84,RM99 (N70-1,N70-5)
    10.Self Tests monitor introduced.
    11.Unlock of DCT4+ (BB4.1 ASIC 2 & 11) phones.
    12.Certificates backup for BB5 phones introduced ("Rd Cert"and"Bk.308"for SL_Data)
    13.BB5 File System Format introduced.
    14.Windows Vista(tm) 32bit OS support.
    LG_GSM v2.0.5.0
    1. KG110, KG320 support fixed.
    2. Added new models.
    3. Windows Vista(tm) 32bit OS support.
    SAMs v2.0.5.0
    COMMON
    Cut Power option (Restart - power on mobile)
    TRIDENT
    C140,C216,C240,C250,C260,C266,C268,C308,P310,P318, X166,X636 added.
    MSL1 bypass, allows direct unlock.
    OM635x
    E635 added.
    SWIFT
    E256,E376,E480,E488,E736,E750,E758 added.
    E25x direct unlock.
    Full TFS Read, TFS editor.
    Option to exclude E2P part from MCU read.
    All other modules have been updated to include Windows Vista(tm) 32bit OS support
    B.R.
  2. ( taihv™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    hoamobile2008 (22-11-2009)
    Product Manager Hoang Thong Mobile's Avatar
    Dec 2006
    Mặc định HWK Release 23/05/2007
    Release Date: 23/05/2007
    The Official release is in our download area www.ufsxhwk.com.
    WARNING !!!
    DCTxBB5 v2.0.5.3
    1. Modified BB5 codes enter, to allow unlock "Counter Expired".
    Many thanks to all those who have supported us!!!
    CTY TNHH ĐIỆN THOẠI DI ĐỘNG HOÀNG THÔNG
    ĐT/FAX : 083.9572152 - 08.38575707 - 0903.303.717
    Skype : saigonmobile
    YM : saigonmobile_vn
    MSN : saigonmobile@hotmail.com
  4. ( Hoang Thong Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    hungckn (03-07-2009)
  5. #3
    Thành viên chính thức nguyenlong248's Avatar
    Feb 2007
    thanks admin
    Dec 2006
    Mặc định HWK Release 29/05/2007
    Release Date: 29/05/2007
    The Official release will be ready in our download area www.ufsxhwk.com.
    You can download from here, until the support site can be updated:-
    http://rapidshare.com/files/34039781...5.004.exe.html
    WARNING !!!
    SAMs V 2.0.5.4
    TRIDENT
    U600,U608 added.
    "Test Mode" enter improved.
    Warning about Battery usage, during UI operations.
    Corrected Reserved Regions for some models(D83x,D84x,E90x,P31x,X82x)
    Added MSL calculation, allows direct unlock and show correct
    codes for new models(D83x,E570,E90x,P31x,U60x,X5xx,X63x,X68x,X8x x,.)
    IMEI challenger implemented, allows rebuild IMEI for new models.
  7. ( Hoang Thong Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    anh0000 (14-11-2009)
  8. #5
    V.I.P tunglep's Avatar
    May 2007
    anh Hoàng Thông ơi? sao e cài bản V 2.0.5...nào vô cũng không được vậy?em mới click vô bản cài là nó báo lỗi rồi sụp win luôn hà,em đã remove hết bản cũ+driver rồi mới cài.cứu em với?thank anh nhiều
  9. #6
    Thành viên chính thức MotoX's Avatar
    Apr 2006
    Trích Được post bởi tunglep Xem bài viết
    dzui quá ! vấn đề nói nhiều rồi, nếu không sẳn các thứ để FIX thì cứ việc setup WIN lại rồi chạy vô tư.
    MotoFONE_F3_R3T621_G_15.08.03I
  10. #7
    V.I.P S-Mobile's Avatar
    Nov 2005
    Bạn thử làm theo cách này xem nhé
    Chuột phải vào các file Setup này - Properties-Compabitility-Trong mục Compatibility Mode trỏ vào mũi tên chọn Windows NT4.0 - OK
    Xong giờ bạn thử cài xem có được ko . Chúc thành công
  11. #8
    Nov 2005
  12. #9
    Thành viên mới hnt20042000's Avatar
    Jan 2007
    phải có n page mới dám thử ke ke
  13. #10
    Thành viên mới phuonganhpt's Avatar
    May 2007
    Trích Được post bởi Hoang Thong Mobile Xem bài viết
    WARNING !!!
    SAMs V 2.0.5.4
    TRIDENT
    U600,U608 added.
    cám ơn bác xuân nhé
    chì có HWK zin mới được nhé các bạn!! chú ý nếu chíp HWK lô là ngũ luôn đó
  14. ( phuonganhpt ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    tech24h (22-01-2009)
  1. ChimeraTool - Samsung custom root image update, Lumia update ChimeraTool update: v 9.45.1819 03/03/2016 Added Samsung
    Bài viết cuối: 04-03-2016, 09:31
  2. Z3X-BOX Samsung Update. 18.1 READ/Write Certificate. N900x. Update of 2014?
    Bài viết cuối: 06-09-2014, 09:34
  3. 08/11/12 Fire Dongle Mix Update Samsung Htc Blackberry Alcatel & Update Fimware Card
    By Lính Khang in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 08-11-2012, 15:57
  4. DANGEROUS UPDATE! Z3X BOX Anniversary Update. Samsung tool v13 Update.
    Bài viết cuối: 21-10-2012, 19:06
  5. Trả lời: 2
    Bài viết cuối: 07-08-2009, 11:35
