Trang 5 của 8 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 CuốiCuối
Kết quả 41 tới 50 của 73
  1. #41
    V.I.P Nguyễn Hữu's Avatar
    Jan 2006
    Các bạn lưu ý đừng có post cái HID của HWK lên đây nhé ! Kẻo hối hận không kịp.
    Quay đầu là ...vực sâu
  2. #42
    Product Manager Hoang Thong Mobile's Avatar
    Dec 2006
    Mặc định HWK Release 10/02/2009
    Release Date: 10/02/2009
    The Official release is ready in our download area http://sarunasoftware.com.
    WARNING !!!
    If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk.
    UFS_DCTxBB5 v2.0.8.2
    1. Flash Update Pack problems Fixed.
    2. New BB5 products:
    RM-247,RM-297,RM-333,RM-334,RM-335,RM-348,RM-349,RM-350,RM-356,
    RM-398,RM-399,RM-415,RM-427,RM-428,RM-429,RM-437,RM-449,RM-450,
    RM-472,RM-493,RM-494
    (N96-1,N96-5,N85-1,N85-3,N85-5,N79-1,N79-3,N79-5,5800d-1,7510a,7510a-b,
    6600s,5800,5800,3610a,E63-1,E63-2,E63-3,N96-3,E71-5,E66-5)
    3. DC4 Flash Chip 0020883C Fixed.
    4. New DCT4 products:
    RH-111,RH-112,RH-113,RM-438,RM-439,RM-490,RM-500
    (1202-2,1202-2b,7100s-2,7100s-2b,1680c-2b,2680s-2b)
    5. New DCT4+ UNL versions support:
    1200(RH-99 v5.71,v5.80) 1202(RH-112 v2.80) 1208(RH-105 v5.71,v5.80)
    1650(RM-305 v5.71,v5.80)
    6. User interface localisation.
    Do not use external VPP adapter with RX2 enabled cables, since this will put VPP direct to RX2 and its possible to KILL the phone.
    LG_GSM V 2.0.8.2
    1. Infineon GB100,GB105,GB106,KG285,KG288,KP100,KP105,KP106,KP 107
    support added. (BIN bundle files open as FLS)
    2. Read/Write for Infineon EGOLD Voice added.
    3. Auto Backup for Infineon EGOLD Voice added.
    4. ADI KF240, KF300
    support added. (BIN bundle files open as Code)
    Cable as for KP130,KP210,KP260
    5. QualComm models introduced.
    SAMs V 2.0.8.2
    TRIDENT
    B270 added (DUNL,IM,FL)
    TRIDENT VISION
    J610 MSL corrected (DUNL,IM)
    E215L,M320L added (CUNL,FL)
    (Use [Reset MMI] if phone ask for password)
    OM(SYSOL)
    M140 added (DUNL,IM,FL,SECT)
    SWIFT
    J706,L708E added (DUNL,IM,FL,SECT)
    SWIFT-AEROFONE
    B130,B130S,B130T fixed flashing for HW 0.600
    QUALCOMM
    ENUMERATION NOT EXIST: 20 bug fixed (up to COM256 supported)
    Fixed flashing for OEMSBL V5.32 and higher (M7500,M8800)
    UNLOCK and UNFREEZE added for these models:
    F480F,M7500(Armani),M8800(Pixon),U700,U700B,U708,U 800,U800F
    (Use [QCDI Info] button to readout keys)
    S7220,S7350 added.
    Samsung / Qualcomm USB Drivers can be downloaded here:-
    http://rapidshare.com/files/19063817...SB_Drivers.zip
    We would like for some users to add localisation in their own native language to the software, localisation is added to SAMs only at the moment but will be added to other modules in future.
    Conditions:-
    1. Only 1 contributer per language.
    2. You must know how to use the software and what each function does.
    3. The chosen language is your native language or you are fluent in the selected language, for example Chinese is not my native language and I would like someone to take over from me and finish/correct as required.
    Many thanks to all those who have supported us!!!
    CTY TNHH ĐIỆN THOẠI DI ĐỘNG HOÀNG THÔNG
    ĐT/FAX : 083.9572152 - 08.38575707 - 0903.303.717
    Skype : saigonmobile
    YM : saigonmobile_vn
    MSN : saigonmobile@hotmail.com
  3. ( Hoang Thong Mobile ) đã được 5 thành viên cám ơn vì bài viết hữu ích!
    DAIPHUC (10-02-2009), duocbienhoa (10-02-2009), hoangxuananh (10-02-2009), TAMTRUONGTELECOM (10-02-2009), xitrumdatphan (15-02-2009)
  4. #43
    Thành viên tích cực paulhung's Avatar
    Dec 2006
    Hiện tại support chưa download được,tam thời down tai đây
  5. ( paulhung ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    amakhe (19-02-2009), chienmobile (12-02-2009)
  6. #44
    Thành viên mới nguyentin's Avatar
    cái này mình chì update thôi phải ko máy PRO còn cái bảng cài thì chưa có phải ko máy anh trai....!,hay là update cái là máy cái bảng mình chạy nó tự lên 2.0.8.2
  7. #45
    Thành viên tích cực NhatDang_DaiSu's Avatar
    Feb 2008
    remover bản cũ chạy lại bản mới
    Website: http://gsm-server.mobi Service unlock code online
  8. #46
    Thành viên mới hiep5505's Avatar
    Trích Được post bởi NhatDang_DaiSu Xem bài viết
    ko cần remove bản cũ .cứ setup chồng lên là dc . ( bản cũ 2.08)
  9. #47
    quocchuong566
    Guest quocchuong566's Avatar
    có ai tes thử bản này chưa các bạn
  10. #48
    V.I.P TânĐạiDương's Avatar
    Jan 2007
    59A QL 13-HBP-Thủ Đức-TP.HCM
    Trích Được post bởi quocchuong566 Xem bài viết
    * Nếu Chíp HWK của bạn update Từ Ver 2.08 rồi thì chỉ cần Setup lần lược từ Ver 2.08.1 rồi tới Ver 2.08.2 là sài ok mình đã thử ok với Ver 2.08.2
    Nhận Bẻ Khóa -Sữa ĐTDĐ Lấy Liền-Nạp Tiếng Việt Sửa Lỗi,Nâng Cấp Phần mềm-389/1A-QL 13-Hiệp Bình Phước-Q.Thủ Đức-TP.HCM-0909445774
  11. ( TânĐạiDương ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  12. #49
    quocchuong566
    Trích Được post bởi anhduongvn Xem bài viết
    thans bạn nhiều,để mình thử coi sao.mình đang sài 2.0.8
  13. #50
    quocchuong566
    mình đã up ok,cảm ơn các bạn
  1. ChimeraTool - Samsung custom root image update, Lumia update ChimeraTool update: v 9.45.1819 03/03/2016 Added Samsung
    Bài viết cuối: 04-03-2016, 09:31
  2. Z3X-BOX Samsung Update. 18.1 READ/Write Certificate. N900x. Update of 2014?
    Bài viết cuối: 06-09-2014, 09:34
  3. 08/11/12 Fire Dongle Mix Update Samsung Htc Blackberry Alcatel & Update Fimware Card
    By Lính Khang in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 08-11-2012, 15:57
  4. DANGEROUS UPDATE! Z3X BOX Anniversary Update. Samsung tool v13 Update.
    Bài viết cuối: 21-10-2012, 19:06
  5. Trả lời: 2
    Bài viết cuối: 07-08-2009, 11:35
