Kết quả 1 tới 3 của 3
    Thành viên mới ktvthaicm's Avatar
    Jun 2006
    Talking Unlock C975 ok
    mình Góp ý tí nhé
    C975 (fw … 91i) unlock ok
    Connect powered ON handset to PC via Smart-Clip (phone > USB cable > Smart-Clip > LPT cable > PC).
    Connect S-Card to PC USB port.
    Connect power supply to Smart-Clip and power on the handset.
    Launch SmartMoto.
    Choose "Smart-Clip USB port" in phone connection window.
    Press "Search". Software should perform the following steps:
    SmartMoto detects S-Card;
    SmartMoto detects Smart-Clip;
    SmartMoto detects the handset and reads all information.
    The next steps depend on the phone boot version. Follow the instructions in the schedule, please.
    Boot 6.36
    Boot 6.31
    Boot 5.F1/ 6.10/ 6.12
    Log to bookmark "Prepare".
    Select the appropriate model from SmartMoto list. Make sure that phone model and boot version of the phone to be unlocked exactly match the model and boot version stated in the list.
    Press "Prepare" button.
    The prepare cycle starts. SmartMoto creates a Temporary Backup File from the handset firmware.
    At this time popup window appears at SmartMoto interface. Please follow the instructions provided therein
    Disconnect cable from the phone;
    Remove and insert phone’s battery;
    Press "Power on" key on the phone. Phone's LCD remains blank;
    Connect cable to the phone;
    Press OK in SmartMoto.
    The handset should be detected by SmartMoto as "S Blank..."
    SmartMoto restores the temporary backup file.
    Log to bookmark "Unlock".
    Pickup correct model from the scrolling list.
    Press "Remove RSA".
    Phone goes into boot mode. Reserve copy of security area is created.
    Part of phone firmware is reflashed.
    Phone doesn't power on after that. SmartMoto will give the message requiring to take phone into boot mode by pressing keys combination: *,#, PWR ON (at this moment the phone has to be connected with USB cable).
    Press "OK" button. Wait till the process finishes.
    Log to "Flash" tab.
    Press "Enter flash mode".
    The phone enters a flash mode (continue with the step 14, please).
    P.S. Alternatively, the handset can be connected using a TestPoint method. After that log to bookmark "Flash", press "Enter flash mode" and continue with the step 14.
    Press "Unlock via patch" button.
    Wait for the process to complete.
    Phone is unlocked. lụm tiền bỏ túi
    V.I.P LinhNC's Avatar
    Nov 2006
    Usa
    Có gì đặc sắc đâu???
    PUB[/B]
    Thành viên tích cực son_nx2007's Avatar
    Apr 2007
    con này có scard hoặc mss4 là làm được thôi mà
  1. tiếng việt C975
    By sihungdt in forum Phần mềm Motorola
    Bài viết cuối: 15-05-2009, 15:19
  2. C975 không xạc được
    By kldmobile_pc_2010 in forum MOTOROLA
    Bài viết cuối: 21-12-2007, 11:41
  3. cần tv c975 gấp
    By monkeykho in forum Phần mềm Motorola
    Bài viết cuối: 07-12-2007, 11:44
  4. SOS Unlock Moto C975
    By hacker2510 in forum P2K Series
    Bài viết cuối: 24-11-2006, 23:11
  5. C975 lạ quá
    By S-Mobile in forum MOTOROLA
    Bài viết cuối: 03-07-2006, 22:16
