Giúp em với các anh ơi. Em up fw con N80 của em bằng hộp JAF thì bây giờ bật không lên nguồn nữa. Nó báo lỗi can't make look data backup using pm field 308. Ai giúp em với không em chết mất. Điện thoại yêu dấu, hu hu
 Up FW máy N80 IE bị lỗi
				post nguyên cái log lên , không có bỏ 308 chạy lại .
tueyennhi (31-01-2010)
				JAF version 1.98.61
Detected PKEY: 9002D429
Card life counter: 100.00%
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30112
USB Cable Driver version: 7.0.2.0
Changing mode...Done!
Booting phone...
FAST PHONE detected!
APE Boot Data:
Asic ID: 17100708
Asic Mode ID: 00
Asic Public ID: DA1917690632BC251E907029344041393CE92A10
HASH: 49A97E826B93BA20B7ED0B082475C00500000000
ROM ID: 1DFD66132C872FD4
CMT Boot Data:
Asic ID: 000000010000022600010006010C192101003000
Asic Mode ID: 00
Asic EM ID: 00000B22
Asic Public ID: 134001065BA10154E381A3E2860F0FE5A05661D9
HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
ROM ID: 273F6D55DFAAF68F
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
Loader version: 01.1E.00 -> Revision: 0000
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
CMT Boot Ready
CMT Flash ID: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.21.01 -> Revision: 0000
Patching CMT loader step1...
Patching CMT loader step3...
CMT Loader Ready
APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg
Loader version: 01.23.00 -> Revision: 0000
Patching APE boot step1...
Patching APE boot step2...
Patching APE boot step3...
APE Boot Ready
APE Flash ID: 00A100EC <=> SAMSUNG (SEC) -> K5E1G12ACM
APE Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Done!
Restarting phone...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-92\
Scanning for ini files...
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-92\N80_5.0725.0.1-prd_western_C00_cc.fpsx
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-92\N80_rofx_5.0725.0.1-prd.V10
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-92\N80_userarea_5.0725.0.1-prd.U04
APE Variant file: ?
Languages in ppm: English,Chinese
Backing up CRT data...
Setting FLASH MODE
CMT Boot Ready
CMT Loader Ready
Reading CMT NPC certificate...
Reading CMT VARIANT certificate...
Reading CMT CCC certificate...
CCC not available...
Reading CMT HWC certificate...
HWC not available...
Saved to C:\Program Files\ODEON\JAF\ProgData\35881400377690_CRT_backup _195311.rpl
Backup CRT OK!
Backing up SIMLOCK data...
Setting local mode...
Reading IMEI...
Failed! Aborting!
Failed to backup LCK...
Sau đó nó hiện thông báo can't make look data backup using pm field 308 và hỏi mình có tiếp tục không. Em bấm yes thì chạy một lúc nó hiện dòng Error sync the phone.
				Bây giờ kiếm cọng cáp khác chuẩn , bỏ cái dấu 308 đi chạy lại . cọng cáp của em bị lỗi rồi...
				Anh ơi, bỏ cái dấu 308 là sao hả anh ?
				có 2 cái ô vuông CRT 308, và CRT bk , bỏ cái dấu tick của crt 308 rồi chạy nhớ kiếm cọng cáp chuẩn.
				Trường hợp cap không chuẩn có sao không anh ? Ý nghĩa bỏ tích CRT 308 là gì ạ? Làm phiền anh quá.
				cáp không chuẩn dẫn đến eror sync the phone như là nó không nhận máy 1 cách chuẩn mặc dù vẫn check , info ok , chắc ăn kiếm cọng cáp khác thử , bỏ 308 khi mà khi nó báo không thể backup được thì thay vì bấm yes thì cancel chạy lại bỏ crt 308 thì nó sẽ ok .
				Hé hé, cảm ơn anh rất nhiều. Em bỏ dấu tích và vẫn dùng cable đó. ok roài. hí hí. Thank anh nhiều nha. Nếu anh có đây nhất định mời anh đi uống nước
jerrylevu (31-01-2010)
