    Thành viên chính thức liemmobile's Avatar
    Apr 2008
    Mặc định Nhờ anh em xem hộ. N1200
    Em vừa nhận con máy n1200 của khách. hoạt động được một lúc thì sập nguồn. Các bác xem hộ em nhe.
    Check..
    Getting MCU ID
    MCU ID: 0x2292
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 5.51
    16-06-08
    RH-99
    (c) NMP
    HW version: 2502
    PCI version:
    UEM version: 1328
    UPP version: 8850
    RFIC version: 0700
    DSP version: ICPR62_08w21_U
    LCD version: WIN:MYKS:04
    ST7507
    PPM version: V 5.51
    16-06-08
    RH-99
    (c) NMP
    MR
    ADSP SW version: V 5.51\n16-06-08\nRH-99\n(c) NMP\nmr
    Production serial number: IAP870310
    Product code: 0546885
    Module code: 0203402
    Basic production code: 0566784
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: ???????????????
    IMEI spare to net: FA FF FF FF FF FF FF 0F
    IMEI SV to net: F3 FF FF FF FF FF FF 6F F1
    Master Code: 5013663745
    Phone type: RH-99, Software version: 5.51, Language Pack: MR
    User code: ÿ#
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
    Setting local mode...
    Reading product code...
    Product Code: 0546885
    Checking path: \Products\RH-99\
    No ini files found...
    Done!
    Em cảm ơn nhiều.
    Thành viên mới huynhduy's Avatar
    Trích Được post bởi liemmobile Xem bài viết
    Check..
    Getting MCU ID
    MCU ID: 0x2292
    Algo is ready...
    Done!
    Phone Restarted...
    Reading...
    16-06-08
    RH-99
    (c) NMP
    HW version: 2502
    PCI version:
    UEM version: 1328
    UPP version: 8850
    RFIC version: 0700
    ST7507
    PPM version: V 5.51
    16-06-08
    RH-99
    (c) NMP
    MR
    Flash code:
    Order number:
    Long production SN:
    ATO:
    Default SN type:
    User code: ÿ#
    Done!
    Em cảm ơn nhiều.
    tốn 1 log rối liem ơi
    V.I.P phatdat_dtdd's Avatar
    Mar 2007
    bạn xem ;
    Default SN type:
    phatdat_dtdd & Q4 tphcm
    Apr 2008
    bác nào có log cho em xin 1 cái với
    Rh-99-356424024254999.
    Em cảm ơn trước.
    ĐÔ LƯƠNG _ NGHỆ AN
    nếu không kiếm được thì thay ic nguồn + flat = 0k
    Apr 2008
    bảo em thay ic _ flat con máy rách thà em mua log 5-10k còn hơn. Đỡ phải xin.
    cách này không được. ai hảo tâm cho em xin 1 log đi
    Apr 2008
    Cao thủ đâu hết rồi
    Jan 2009
    Qua YM mà lấy log anh nhé
    Apr 2008
    anh cho em nik name di
  1. Xin Log N1200
    By quochung0211 in forum DCT4 - WD2
    Trả lời: 13
    Bài viết cuối: 05-07-2012, 13:44
  2. Sửa chữa N1200...bằng hình ảnh-''VIỆT NAM''.
    By PHÁ_Mobile™ in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 27-10-2010, 10:55
  3. N1200 rơi nước, IMEI ??????????????????????
    By tranvantinh in forum DCT4 - WD2
    Trả lời: 17
    Bài viết cuối: 12-03-2010, 12:11
  4. n1200 xin hỏi các anh
    By trithanh-dvcd in forum BB5
    Bài viết cuối: 27-07-2009, 09:51
  5. N1200 mp4
    By trantamweb™ in forum Phần mềm và các mã lệnh
    Bài viết cuối: 15-02-2009, 09:13
