mình nhận một cây 1200 bấm nguồn lên 2s rồi trờ về không ,mình đã chạy lài phần mềm nhưng vẫn không đeược, làm cpu, flash ,ic nguồn rồi mà vẫn vậy anh em náo gặp qua trường hợp này chỉ mình với
anh em xem thử dùm mình cái log này xem có vấn đề gì không
ing MCU ID
MCU ID: 0x2292
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 5.91
27-03-09
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: ICPR62_08w31_UPP
LCD version: UNKWN: IDs:
00:ff:00
PPM version: V 5.91
27-03-09
RH-99
(c) NMP
MR
ADSP SW version: no NAI version
Production serial number: IGR087265
Product code: 0546885
Module code: 0203402
Basic production code: 0566784
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 354167021331532
IMEI spare to net: 3A 45 61 07 12 33 51 03
IMEI SV to net: 33 45 61 07 12 33 51 73 F0
Master Code: 6641646615
Phone type: RH-99, Software version: 5.91, Language Pack: MR
User code: ے#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file D:\Program Files\ODEON\JAF\JAF_RH-99.ini
Setting local mode...
Reading product code...
Product Code: 0546885
Checking path: D:\Program Files\Nokia\Phoenix\Products\RH-99\
Checking path: \Products\RH-99\
No ini files found...
Done!
