máy bị rơi đât bật nguồn treo và khởi động lại mình là làm lai cpu và flash không đc, cho vào box chạy qua MXkey báo vậy
Library version: 1.0.0.11985, Date: 03-02-2010
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 00298CA0A3BDA66
ASIC type: 11
UEM Imei: 35801503622874
Flash Imei: 35801503622874
RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35801503622874_BA CK.rpl"
Processing file: rh112_003.000 as MCU
[DCT4,DCT4 ALGORITHM] size: 2.29 MB
Supported Ids: 2293
UEM ID: 00298CA0:2984DA60
Area [01000000-0100FFFF] erased in 1.063 s
Area [01010000-013AFFFF] erased in 59.328 s
Area [013B0000-013EFFFF] erased in 4.156 s
Area [017C0000-017EFFFF] erased in 0.078 s
Area [01FC0000-01FEFFFF] erased in 0.078 s
Flash programming ...
Programming completed in 17.296 s
File Processed in 1 min 33.375 s
Processing file: rh1120_nai03.00mr as CNT
[DCT4,DCT4 ALGORITHM] size: 110.51 KB
Supported Ids: 2293
Area [01380000-013AFFFF] erased in 3.109 s
Programming completed in 0.844 s
Content extract fail, continue anyway ...
File Processed in 1 min 11.859 s
Processing file: rh112_003.00mr as PPM
[DCT4,DCT4 ALGORITHM] size: 1.14 MB
Supported Ids: 2293
Area [01240000-0124FFFF] erased in 1.032 s
Area [01250000-0137FFFF] erased in 19.281 s
Programming completed in 8.656 s
File Processed in 36.000 s
Flashing completed in 4 min 22.485 s
Phone not responding !
Total time to process is 11 min 9.750 s
			 nhờ anh em xem giúp log 1202
			 Được post bởi gyong
 Được post bởi gyong
