W380a unlock ok By setool sau đó convert qua W380 có TV luôn sài 5 mạng ok luôn
Code:SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED CFG:101111000000 ChipID:D000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35786402496724 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER FLASH ID:2019 LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER loader GDFS startup executed loader FILESYSTEM startup executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM64 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID:D000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 Starting embedded bootloader... INT LDR:PNX5230_PRELOADER_FOR_SETOOL2 LDR:PNX5230_PRODUCTION_LOADER_FOR_SETOOL2 FLASH ID:2019 FOUND VERSION "R10BA015_1201-4421_GENERIC_LE" can't open file "C:\Setool\rest\R10BA015_1201-4421_GENERIC_LE" writing "C:\w380\R10BA015_APP_SW_1201_4421_GENERIC_LE_RED_CID53_PNX5230.software" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9600 Will flash 480 blocks... writing "C:\w380\R10BA015_FS_APAC_LE_RED_CID53.software" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 2820 Will flash 141 blocks... USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. LDR:PNX5230_FILESYSTEMLOADER_FOR_SETOOL2 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 564 secs.
