Tin Nay Mình Chỉ Biết được Từ Trang Truongvinh.com
 Các Bạn Có Thể Unlock Một Số Bb5 Tại Chỗ
				bóc tem
Bầy sẻ cũ cũng qua đời lặng lẽ,
Con dế buồn tự tử giữa đêm sương...
				Nhớ ai nhớ mãi thế này
Nhớ đêm không ngũ nhớ ngày quên ăn
				có tool free rồi
				đây nè các anh ngâm cứu đi
hướng dẫn nè :
TÔI TEST 6680/6630 VODAFONE OK
1. Connect DKU-5 or normal COM cable to computer
2. Set proper COM cable (must be, between 1 and 9)
3. Download unlocker, run `install.bat`
4. Open file c:/bb5_unlocker/logs/bb5_unlocker.cfg and write here proper COM port (1-9)
5. Run c:/bb5 unlocker/BB5logunlocker.exe
6. Click READ PHONE
7. Click MAKE LOG, log will be created
8. Enter codes to phone (in /psw/ dir), or
9. Click SP UNLOCK to enter codes via FBUS
Instructiuni de la mama lor:
******* CONECTION ******
For this program you need Fbus cable like DK5, CA43 or similar conected to ports from COM1 to COM9.
First unpack zip fiole and strat install.bat
In file "c:\bb5_unlocker\logs\bb5_unlocker.cfg" with any text editor change your COM port setings!
******* USING ********
Program can be started successfully only if is COM port in file "c:\bb5_unlocker\logs\bb5_unlocker.cfg" adjusted properly.
READ PHONE:
Reading info data from phone and making BACKUP file for that phone( Field 308,1).
IMPORTANT DO NOT delete or modify that file because can save your *** if something goes wrong.
WR BACKUP:
With that function can write backup file with Field 308,1 if exist in BACKUP folder.
MAKE LOG:
Function for making log file . With that log file BB5_calc.exe calculating codes for unlock.
Working with BB5 phones with RAP3G v.2.x (6630,6680,6681,6682,n70,n90).
IMPORTANT phone must be without Sim card.
SP UNLOCK:
Making unlock with codes calculated by BB5_calc.exe.
SP UNLOCK PROCEDURE
Connect cable to PC and be shure com port is adjusted properly
Start BB5logunlocker.exe
Connect phone and switch on without Sim card.
press button READ PHONE and wait until get the message DONE.
If is everything correct you will see info from phone on screen.
Pres button make log and wait until get mesage done.
Log file is in folder LOGS.
Start BB5_calc.exe to make for you PSW file in folder PSW
Press button SP UNLOCK and unlock your phone.
That is all.
If you got unlock codes from your provider and you used all yours 3 attempts
to enter code via keypad then do the following:
into dir "c:\bb5_unlocker\psw" create a file "aaaaaaaaaaaaaaa_BB5.psw" where is "aaaaaaaaaaaaaaa" enter your phones imei
then in that created file enter in the files start "#pw+bbbbbbbbbbbbbbb+c#" where is "bbbbbbbbbbbbbbb"
enter your unlock code and where is "c" enter your logs level number (1-7).
save the file and use "SP UNLOCK" function
6680 VODAFONE
IMEI:355664005729623
#pw+182527072485690+7#
#pw+495001853663892+6#
#pw+371822477080650+5#
#pw+025851073123217+4#
#pw+385950564933301+3#
#pw+325095735419483+2#
#pw+272114172191401+1#
TIẾC QUÁ KHÔNG UPLOAD ĐƯỢC CÁI HÌNH LÊN
của người ta test đó em chỉ thấy hay hay gởi lên mấy anh ngâm cứu
				lụm tiền thui chứ ngâm cứu gì nữa
				''NGÂM'' nhiều quá dấm nó chua ko nuốt nổi
Best Regards
				Chuyến này ae kỹ thuật của mình khỏe rồi
 lại trời
 lại trời
				chúc cho mọi việc đều đúng
nghề nào k có giá của nó
vậy sửa điện thoại chuẩn bị bao nhiêu là đủ .... đền
