Kết quả 1 tới 10 của 13
    Thành viên mới thanhpromobile's Avatar
    Aug 2008
    Mặc định Xin Anh Em Giúp Đỡ 6020 chết nguồn
    Máy 6020 chết nguồn ,em đã thay cpu , nhưng chạy lại phần mềm máy báo lỗi , nhờ anh em giúp đỡ , xem giùm em cái log
    MCU ID: 0x2142
    FLASH ID0: 2C7E0001 <=> SPANSION -> 72NS128N Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: D:\HE DIEU HANH\NOKIA\DCT4+WD2+BB5\RM-30\rm30__04.100
    Booting phone...
    MCU ID: 0x2142
    Boot size is 0x09A0
    Boot is ready...
    Flash ID is 0x7E2C0100
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: 10
    Loader is ready...
    MSID: 845C95F58A060A38915F732315
    MSID decoded: 8FA4BAE900C1A071A9000000
    FAID: 091C7D017D2D0E31B14FB9F8
    Erasing...
    Found 3 interval(s) to erase
    Erasing area: 01020000 - 0185FFFF...
    Erasing area: 01E60000 - 01FDFFFF...
    Operation took 0 minutes 54 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 1 minutes 33 seconds...
    Restarting MCU...
    CNT: D:\HE DIEU HANH\NOKIA\DCT4+WD2+BB5\RM-30\rm30__04.10.image_t
    Booting phone...
    MCU ID: 0x2142
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 842ED4AB3AC5B36085EAB189CD
    MSID decoded: 1C15BAE300C1A071AD0005BD
    FAID: 7A49D259DCEAA8C8DD727015
    Operation took 0 minutes 6 seconds...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01A60000 - 01E5FFFF...
    Operation took 0 minutes 23 seconds...
    Writing...
    Writing converted flash to 128k page
    Operation took 0 minutes 21 seconds...
    Restarting MCU...
    Extracting Content Pack...
    Error setting local mode...
    CP Extract Failed!
    PPM: D:\HE DIEU HANH\NOKIA\DCT4+WD2+BB5\RM-30\rm30__04.10t
    Booting phone...
    MCU ID: 0x2142
    Boot size is 0x09A0
    Boot is ready...
    Loader size is 0x7518; Loader chk: f0
    Loader is ready...
    MSID: 840C69902B524B89D98A85EDA8
    MSID decoded: 3E4EBAE900C1A071A8000000
    FAID: A32F12595841E1B899CF7770
    Erasing PPM...
    Erasing area: 01860000 - 01A5FFFF...
    Writing...
    Operation took 0 minutes 19 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 5 minutes 11 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Aug 2008
    Không ai Giúp Em Vậy ?
    V.I.P nhanvnn's Avatar
    Như Xuân_Thanh Hóa
    Bạn xem lại chân pin đi bạn ơi. no báo ko boot được máy do đương appe BSI rồi
    Thành viên tích cực hoanglinhmobiphone's Avatar
    bạn thử kẹp nguồn kim nó báo sao nha bạn
    Thành viên chính thức anhtuan050478's Avatar
    May 2007
    thay con flash inter thử coi, flash spanion nó kén fw lắm
    Aug 2008
    em kẹp nguồn màn hình lên trắng rồi tắt
    Aug 2008
    Nhờ anh em giúp đỡ
    May 2007
    Trích Được post bởi anhtuan050478 Xem bài viết
    chạy fw 4.91 thử coi nha
    vậy cpu thay chuẩn chưa nếu chuẩn rồi thì nhổ con nguồn ra đóng lại thử xem sao nha bạn
    Thành viên kỳ cựu THANH TRUNG's Avatar
    Kiên Giang
    nếu chắc chắn cpu sống thì thay con flash đi anh.
  1. 6020 mất nguôn cần ace giúp đỡ
    By binhmob in forum DCT4 - WD2
    Bài viết cuối: 12-11-2011, 10:29
  2. 6020 thay ic nguồ báo hạn chế dt cấn giúp
    By nguyenthi in forum DCT4 - WD2
    Trả lời: 15
    Bài viết cuối: 02-10-2011, 21:57
  3. xin giúp 6020 nguồn chập chờn
    By ductien_mobile in forum DCT4 - WD2
    Bài viết cuối: 10-01-2010, 09:34
  4. 6020 vô nước chạm nguồn ..nhờ anh em giúp.
    By tuonglammobile in forum DCT4 - WD2
    Bài viết cuối: 12-10-2009, 11:44
  5. 6020 mất nguồn cần anh em giúp đỡ
    By huuthien in forum DCT4 - WD2
    Trả lời: 16
    Bài viết cuối: 19-10-2007, 09:54
