LG 2G tool 1.0.5 Update ) Just one more small update
Added:
- F7200 full support ( unlock, imei repair, firmware write/read, cal.data write/read, full write/read)
- F7250 full support ( unlock, imei repair, firmware write/read, cal.data write/read, full write/read)
- F9100 full support ( unlock, imei repair, firmware write/read, cal.data write/read, full write/read)
- F9200 full support ( unlock, imei repair, firmware write/read, cal.data write/read, full write/read)
- GB108 full support ( unlock, imei repair, firmware write/read, cal.data write/read, full write/read)
- MG270 full support ( unlock, imei repair, firmware write/read, cal.data write/read, full write/read)
- direct imei via flash mode for:GB100
- direct imei via flash mode for:GB101
- direct imei via flash mode for:GB102
- direct imei via flash mode for:GB105
- direct imei via flash mode for:GB106
- direct imei via flash mode for:GB109
- direct imei via flash mode for:GB110
- direct imei via flash mode for:GB115
- direct imei via flash mode for:GB125
- direct imei via flash mode for:GB126
- direct imei via flash mode for:GB130
- direct imei via flash mode for:KG270
- direct imei via flash mode for:KG271
- direct imei via flash mode for:KG275
- direct imei via flash mode for:KG276
- direct imei via flash mode for:KG278
- direct imei via flash mode for:KG285
- direct imei via flash mode for:KG288
- direct imei via flash mode for:KG289
- direct imei via flash mode for:KG370
- direct imei via flash mode for:KG375
- direct imei via flash mode for:KP100
- direct imei via flash mode for:KP105
- direct imei via flash mode for:KP105A
- direct imei via flash mode for:KP105B
- direct imei via flash mode for:KP106
- direct imei via flash mode for:KP106A
- direct imei via flash mode for:KP106B
- direct imei via flash mode for:KP107A
- direct imei via flash mode for:KP108
- direct imei via flash mode for:MG100
- direct imei via flash mode for:MG101
- direct imei via flash mode for:MG105
- direct imei via flash mode for:MG160A
- direct imei via flash mode for:MG160B
- direct imei via flash mode for:MG161
- direct imei via flash mode for:MG370
