Kết quả 1 tới 4 của 4
    Thành viên mới keodinhchuot_vtv's Avatar
    Mar 2008
    Mặc định 1110i flash bằng JAF xin được giúp đỡ !
    Vấn đề về JAF ,xin được giúp đỡ !
    Mình flash máy 1100i thấy báo thế này ,các bác xem log rùi giúp mình 1 tay .Thanks .
    Getting MCU ID
    MCU ID: 0x2201
    FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 7.02
    10-12-07
    RH-93
    (c) NMP
    HW version: 0526
    PCI version:
    UEM version: 1328
    UPP version: 8705
    RFIC version: 0500
    DSP version: P05w06.v34
    LCD version: UNKWN: IDs:
    00:ff:00
    PPM version: BB^µƒãŸV
    ¹£ï¿
    ADSP SW version: no NAI version
    Production serial number: IBH052276
    Product code: 0537102
    Module code: 0203169
    Basic production code: 0536354
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 358655015068306
    IMEI spare to net: 3A 85 56 05 51 60 38 00
    IMEI SV to net: 33 85 56 05 51 60 38 40 F5
    Master Code: 4147570343
    Phone type: RH-93, Software version: 7.02, Language Pack: ¹£ï¿
    User code: ÿ#
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-93.ini
    Setting local mode...
    Reading product code...
    Product Code: 0537102
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
    Checking path: \Products\RH-93\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02md
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02md
    Languages in ppm: English,Filipino,Vietnamase
    Done!
    Changing flashing settings...
    Reading...
    Reading IMEI...
    Reading IMEI data...
    IMEI data corrupt...
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Flash ID is 0x72888900
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia
    Loader size is 0x5538; Loader chk: bb
    Loader is ready...
    Error Auth!
    .............Kí cái j mà kí .......lâu lắm rồi có đụng đến bút sách j đâu . Vậy bgio kí cái je` =))
    Thành viên chính thức phamtuan_mobile86's Avatar
    bạn vệ sinh kỹ chạy lại coi
    ạkvaklmGv
    Mar 2008
    Hjhj ,thanks bạn . Minh vệ sinh lại + thay cab , Flash ngon lành rùi
    Thành viên chính thức luxithach's Avatar
    con nà se9m qua n_box flash ok lam
    Chú ý khổ chủ đã làm ok không spam bài nha bạn .
    "Hjhj ,thanks bạn . Minh vệ sinh lại + thay cab , Flash ngon lành rùi "
    chuyên sưã chưã tất cả dtdd ,sưã không đươc trả lại
    luximobile call:0975888864
  1. flash 1110i báo loi
    By minhduchtp in forum DCT4 - WD2
    Bài viết cuối: 17-07-2011, 08:13
  2. 1110i flash trang man
    By vietthang_gsm in forum DCT4 - WD2
    Bài viết cuối: 17-06-2010, 10:40
  3. FLASH 1110i
    By thanhhp in forum DCT4 - WD2
    Bài viết cuối: 23-08-2009, 18:47
  4. file flash 1110i ver 6.93
    By tuannhan in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 14-03-2009, 16:11
  5. xin flash file 1110i
    By nguyenmanhtuan_k9c in forum DCT4 - WD2
    Bài viết cuối: 11-12-2008, 15:28
