    Mặc định 7610 sạc pin mất nguồn
    em có cây 7610 sạ
    Detected PKEY: 9002CF36
    Card life counter: 92.34%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Failed! Aborting!
    Failed! Aborting!
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\
    Checking path: \Products\RH-51\
    No ini files found...
    Phone Type:
    MCU Flash file: D:\PHAI NOKIA\phai nokia\rh-51\RH51_52_67_68PE706420.C1
    Phone Type:
    PPM Flash file: D:\PHAI NOKIA\phai nokia\rh-51\RH51PE706420.45
    Phone Type:
    CNT Flash file: D:\PHAI NOKIA\phai nokia\rh-51\RH51PE706420.01
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: D:\PHAI NOKIA\phai nokia\rh-51\RH51_52_67_68PE706420.C1
    Booting phone...
    MCU ID: 0x1081
    BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia
    Boot size is 0x10D8
    Boot is ready...
    FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
    FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
    FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
    Flash ID is 0xDDFE00EC
    Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia
    Loader size is 0x7F10; Loader chk: 4
    Loader is ready...
    MSID: 84E2A955F12EE2A20F88CD6C66
    MSID decoded: 3E4EBAF700892B1DA9000000
    FAID: EC046D8F9582D10886FB6DDF
    Operation took 0 minutes 18 seconds...
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 00000000 - 0000FFFF...
    Erasing area: 00010000 - 00FFFFFF...
    Erasing area: 02000000 - 0287FFFF...
    Erasing area: 02FC0000 - 02FEFFFF...
    Operation took 2 minutes 54 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 3 minutes 13 seconds...
    Restarting MCU...
    CNT: D:\PHAI NOKIA\phai nokia\rh-51\RH51PE706420.01
    Booting phone...
    MCU ID: 0x1081
    Boot size is 0x10D8
    Boot is ready...
    Loader is ready...
    Operation took 0 minutes 19 seconds...
    Erasing Content Pack...
    Found 2 interval(s) to erase
    Erasing area: 02A00000 - 02C9FFFF...
    Writing...
    Operation took 0 minutes 22 seconds...
    Restarting MCU...
    Extracting Content Pack...
    CP Extract Failed!
    PPM: D:\PHAI NOKIA\phai nokia\rh-51\RH51PE706420.45
    Booting phone...
    MCU ID: 0x1081
    Boot size is 0x10D8
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Erasing area: 02A00000 - 02CBFFFF...
    Operation took 0 minutes 20 seconds...
    Writing...
    Operation took 0 minutes 23 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 10 minutes 37 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-51, Software version: 7.0642.0
    IMEI: 352273013977746
    Product Code: 0516453
    Resetting PPC...
    Done!
    Setting test mode...
    Setting FULL FACTORY...
    Operation took 1 minutes 4 seconds...
    Done!
    c pin mất nguồn , khởi động lại lên trắng mh khoảng 5s rồi tắt ae chỉ giúp . chạy ct không hết log của nó đây
    cao thủ đâu hết rồi k ai giúp e hết vậy
    Thành viên tích cực langtungheo's Avatar
    NINH BINH
    Trích Được post bởi ngocbinh_quangtri Xem bài viết
    có ufs thì flash lại và fomat unser cho nó . ko thì bạn fomat 4 ngón chi nó đi. chúc thành công
    điện thoại đẹp chỉ là nhất thời, sim đẹp mới là mãi mãi.Trần văn Tú SDT:0939 68 05 68 & 0979 436 078
    V.I.P HẢI THỌ's Avatar
    Apr 2008
    biên giới campuchia!!
    bệnh này thường chỉ cần thay con N130 là ok thui!chúc may mắn!
    Dtdđ-VŨ HÀ
    0916.775.115
    cứu với mấy huynh ơi !!!!!!!!!!!!!!!!!!!!!!!
    cảm ơn ae nhưng fomat 4 ngón k hết
    Thành viên chính thức trongnghiacoco's Avatar
    vietfones.vn
    dùng ufs fomat 4mat cho nó 1 phát anh
    cho em hỏi con n130 nó sài chung với những máy nào vậy a
    còn cách nào khác k ae đã thay n130 nhưng k hết !!!!!!!!
