    Thành viên mới sonhaf7's Avatar
    Mặc định 1200 lỗi không simlock được
    1200 không thể ulock đươc kể cả chạy bằng jaf và mxkey vậy lỗi do cpu hay nguồn nhờ các anh em giải quyết giúp ...xin cảm ơn nhiều
    dứoi đây là log của em nó chạy bằng jaf FILES SET FOR FLASHING:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.710
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.71mr
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh990_nai5.71mr
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    MCU: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.710
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x28882000
    Loader size is 0x4B38; Loader chk: df
    Loader is ready...
    MSID: 84E614834B8618D9087721275A
    MSID decoded: 3E4EBAE9008436ECAA000000
    FAID: F679B6870BA92A813AD266E2
    Operation took 0 minutes 9 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Operation took 1 minutes 13 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.71mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 84C6BD367DBAFA29F3E08AB986
    MSID decoded: 3E4EBAE9008436ECA8000000
    FAID: 5B48B81C4D96FD30FC73AE72
    Erasing PPM...
    Found 2 interval(s) to erase
    Operation took 0 minutes 23 seconds...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh990_nai5.71mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 33 seconds...
    Setting test mode...
    Setting FULL FACTORY...
    Done!
    Powering the phone...
    Unlocking...
    IMEI: 352902028839638
    Failed! Aborting! Asic 00
    Jan 2009
    Lỗi UPP rồi anh ơi, thay UPP đi
    Thành viên kỳ cựu THANH TRUNG's Avatar
    Kiên Giang
    xóa flash nạp lại bằng HWK xem sao?
    Thành viên mới leson.mobile80's Avatar
    bạn mạng qua hwk thử coi nếu không được mới tính đến phần cứng bạn a. chúc bạn kiếm kèo nhanh nha
    minh làm được rồi ......thanks các bạn nhé
    sao bạn không chia sẻ công thức nhỉ. chúc mừng bạn
    thay cpu và pm lại là ok
    Thành viên tích cực KIÊN NGUYỄN MOBILE's Avatar
    Feb 2010
    TP HCM
    chắc em nó bị tắm nước dùng thơi gian em nó đổ bệnh rui hi hi
  1. C3312 bị simlock
    By microsoft92 in forum Phần mềm Samsung
    Bài viết cuối: 07-03-2014, 22:15
  2. 2730 simlock
    By madao in forum BB5
    Bài viết cuối: 25-02-2012, 13:54
  3. Sagem My c4 -2 bi simlock
    By thach35 in forum CÁC LOẠI ĐIỆN THOẠI KHÁC
    Bài viết cuối: 15-12-2010, 14:23
  4. U700 bị simlock
    By thesmile555 in forum Phần mềm Samsung
    Bài viết cuối: 01-07-2010, 10:49
