"X3 FULL FLASHING Using Fbus 29secs"
AdvanceBox Turbo Flasher Found
Initialize Device....
Init TRY : 1
Changing Clock to 15mhz..
Box Name : AdvanceBox Turbo
Box Firmware : LogiCore 1.16.10
Software Version : v2010.0.1.21
AdvanceBox SN : B57E17A0C7A4ED6DC97700D0
CHECK ACTIVATION : 00
BOX ACTIVATED
DDR DELAY : 01
INIT : OK
CMT Type : BB5
CMT Algorithm : XSR 1.6
CMT Supported Hardwares :
> 020C192102034000
> 0203192102034000
> 020C192102034100
> 0203192102034100
> 0203192102054100
> 020C192102054100
Secondary Sending Speed : 3250000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 19500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 136
Entry Point: 0x0259
Page Format : -1
MAX PAGE : 0x00040000
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2010417160 (0x08) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00000001
ID DWORD 3 : 020C1921
ID DWORD 4 : 02034100
2 ROM_ID 15
Block Length : 5 (05)
ID DWORD 0 : 00001040
3 ROM_ID 15
ID DWORD 0 : 00001030
4 PUBLIC_ID 12
ID DWORD 0 : 28A00117
ID DWORD 1 : AA400E49
ID DWORD 2 : 71E5DB08
ID DWORD 3 : B7C7DD92
ID DWORD 4 : 3EBCDADF
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 67E82268
CRC 1 : F29CEA60
Checksum 39
SearchForBootstrap_DCT5..
Boot File MATCH : RAP3Gv40_2nd.fg
Boot File - Version : 009.048.000
Boot File - Revision : 0x0201
BB5ProtocolType == : New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)
MessageID : C1
SubBlocks : 05
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> Not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> Not used
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0030 -> K5W1G13ACB
Revision ID : 0321
Checksum : 27
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Algo File MATCH : RAP3Gv40_XSR17_alg.fg
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
VPP Enabled by Software
Using Internal VPP
VPPSwitchInfo : VPP1 VPP_GENERATED_IN_PROMMER - VPP2 VPP_GENERATED_IN_PROMMER
CMT Does Not Support 12V VPP
CMT Does Not Support Group Erase
00 unsupported VPP Voltage setting
Using Internal VPP
SendFlashVoltageInit_DCT5
VPP1 0000
VPP2 0000
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D7
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 000A0000
Partition 2
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 02CC0000
Partition 3
Start Address : 077C0000
Partition 4
Start Address : 07B40000
PARTITION_INFO_REQUEST_BB5
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x00E1 (225)
ERASE Blocks : 0x0004 (4)
0 ERASE_AREA_BB5 0x12
Block Length : 0x4B (75)
Device Index : 0x00
0 : 00020000-000203FF
1 : 00060000-0009FFFF
2 : 000A0000-0025FFFF
3 : 003E0000-005DFFFF
4 : 005E0000-010DFFFF
5 : 01EC0000-01EDFFFF
6 : 027C0000-02CBFFFF
7 : 077C0000-07B3FFFF
8 : 010E0000-01EBFFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID :0x02000000
Format Info :0000000000000008000000000000000200000064000000020 000000200000001000000000000
2 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info :000000000000000A000000010000000200000064000000020 000000200000001000000000000
3 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info :000000000000000B000000000000000200000064000000020 000000200000001000000000000
ERASE_REQUEST_BB5 : 5009120B00030000020000000203FF120B0003000006000000 09FFFF120B000300000A00000025FFFF120B000300003E0000 005DFFFF120B000300005E0000010DFFFF120B00030001EC00 0001EDFFFF120B000300027C000002CBFFFF120B000300077C 000007B3FFFF120B000300010E000001EBFFFF3D
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000001
Additional Bad : 00000001
Correctable ECC : 00000000
ERASE_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 0002000000640000000200000002000000010000000000003E
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 0002000000640000000200000002000000010000000000003B
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 0002000000640000000200000002000000010000000000003B
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Successfully erased..
Processing : rm540__04.11.mcusw
Total blocks to write : 136
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
>> CMT Rootkey Hash CERT : MCUSW1
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : ISA+DYNSW
ContinueFlash_DCT5 Complete
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
FlashInfo.RestartMode : 1
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:00:17
Making delay between files for 7000ms
CMT Type : BB5
> 020C192102034000
> 0203192102034000
> 020C192102034100
> 0203192102034100
> 0203192102054100
> 020C192102054100
Number of Blocks : 27
Entry Point: 0x011D
Page Format : -1
Init TRY : 1
BOX ACTIVATED
DDR DELAY : 01
INIT : OK
VBATT OFF ...
VBATT ON
Setting VBATT Done!...
BootFlashMode_DCT5
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 67E82268
CRC 1 : F29CEA60
Checksum 39
MessageID : C1
SubBlocks : 05
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0321
Checksum : 27
SendAlgoCode_DCT5..
Algo Loader Sent...
Using Internal VPP
Using Internal VPP
VPP1 0000
VPP2 0000
No RESTORE CERTIFICATE FOUND IN IMAGE FILE
Partition Info
Device Index : 0x00
Spare : FFFFFFFF
Partition 1
Partition 2
Partition 3
Partition 4
StartErase_DCT5...
BlockLength : 0x000E (14)
ERASE Blocks : 0x0001 (1)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01EE0000-027BFFFF
ERASE_REQUEST_BB5 : 5001120B00030001EE0000027BFFFF74
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Processing : rm540__04.11.ppm_a
Total blocks to write : 27
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
FlashInfo.RestartMode : 2
Time Taken to Flash : 00:00:04
CMT Type : BB5
> 020C192102034000
> 0203192102034000
> 020C192102034100
> 0203192102034100
> 0203192102054100
> 020C192102054100
Number of Blocks : 54
Entry Point: 0x0154
Page Format : -1
Init TRY : 1
BOX ACTIVATED
DDR DELAY : 01
INIT : OK
VBATT OFF ...
VBATT ON
BootFlashMode_DCT5
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 67E82268
CRC 1 : F29CEA60
Checksum 39
MessageID : C1
SubBlocks : 05
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0321
Checksum : 27
SendAlgoCode_DCT5..
Algo Loader Sent...
Using Internal VPP
Using Internal VPP
VPP1 0000
VPP2 0000
Partition Info
Device Index : 0x00
Spare : FFFFFFFF
Partition 1
Partition 2
Partition 3
Partition 4
StartErase_DCT5...
BlockLength : 0x003F (63)
ERASE Blocks : 0x0002 (2)
Device Index : 0x00
0 : 02CC0000-077BFFFF
Device Index : 0x00
ERASE_REQUEST_BB5 : 5001120B00030002CC0000077BFFFF90
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Processing : rm540__04.11.image_a_0580697_001
Total blocks to write : 54
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Time Taken to Flash : 00:00:08
Rebooting Box ...
Init TRY : 1
BOX ACTIVATED
DDR DELAY : 01
INIT : OK
VBATT OFF ...
VBATT ON
Waiting for phone to Power On, 8000 ms delay
Reading Phone Information...
MCU: V 04.11 09-12-09 RM-540 (c) Nokia
IMEI: lemor X3
Simlock Version : SIMLOCK SERVER
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider : AT&T;U.S.A. (3650)
Counters : 0/3 , 0/10
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SP Lock Status : Not Locked
			 First In the World New Loader New Protocol "X3 29secs FBUS Flashing"
