máy chết nguồn kho boot được>>e làm lại uem và upp chạy dở thì báo lỗi này>>ae xem hộ e nhé
Getting MCU ID
MCU ID: 0x2292
FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Setting local mode...
Failed! Aborting!
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
Checking path: \Products\RH-105\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.800
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.80aa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.80aa
Languages in ppm: English,Dannish,Norwegian,Swedish
Changing flashing settings...
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.80mr
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.80mr
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.800
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x72888900
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
Loader size is 0x5548; Loader chk: d9
Loader is ready...
MSID: 84BE2AE8B4D8C80DCD1D9FF26B
MSID decoded: 3E4EBAE9008C87EAA8000000
FAID: C22EA7BFCD7213998349A942
Operation took 0 minutes 9 seconds...
Erasing...
Found 5 interval(s) to erase
Operation took 0 minutes 37 seconds...
Writing...
Error cmd: 14!
Addr: 01000064
			 xem giúp e log 1208
 xem giúp e log 1208
