e nhận khách 110i sài bình thường tự động kô nhận sim khởi dộng máy lại ,e nap chương trình ok mở nguồn kô lên e xóa flash nạp lên 1600 ct lại củng ok mở nguồn lên củng kô đc ,e thay nhiều mh khác vẩn vậy các cao thủ nào gặp wa xin giúp e thask log nó đây CU ID
MCU ID: 0x2201
FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 7.02
10-12-07
RH-64
(c) NMP
HW version:
PCI version:
UEM version: 1328
UPP version: 8705
RFIC version: 0500
DSP version: P05w06.v34
LCD version: UNKWN: IDs:
00:ff:00
PPM version: V 7.02
10-12-07
RH-64
(c) NMP
MD
ADSP SW version: V 7.02\n10-12-07\nRH-64\n(c) NMP\nmd
Production serial number:
Product code:
Module code:
Basic production code:
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 011408001406778
IMEI spare to net: 0A 11 04 08 10 04 76 07
IMEI SV to net: 03 11 04 08 10 04 76 47 F5
Master Code: 5015342211
Phone type: RH-64, Software version: 7.02, Language Pack: MD
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-64.ini
Checking path: C:\Program Files\Nokia\Phoenix\Products\\
Checking path: \Products\\
No ini files found...
Done!
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-64\rh64_07.020
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-64\rh64_07.02md
Languages in ppm: English,Filipino,Vietnamase
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-64\rh640_nai7.02md
Setting local mode...
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\rh-64\rh64_07.020
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x7E2A0100
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
Loader size is 0x7518; Loader chk: c6
Loader is ready...
MSID: 843A75DE4116294CD85F29262D
MSID decoded: 3E4EBAE90053348CA9000000
FAID: 572FD521DCD43F13447CDCE1
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013BFFFF...
Erasing area: 013C0000 - 013EFFFF...
Operation took 0 minutes 34 seconds...
Writing...
Perm. Data Restore OK
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\rh-64\rh64_07.02md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
MSID: 84F7C3FEA0A4F05030BF47AB87
MSID decoded: 3E4EBAE90053348CA8000000
FAID: D773A8308B6962C9BF878E00
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 011D0000 - 011DFFFF...
Erasing area: 011E0000 - 0137FFFF...
Writing...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\rh-64\rh640_nai7.02md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
MSID: 84BBA9EF1965FFAD43C6D17C39
MSID decoded: 3E4EBAE90053348CAA000000
FAID: 5C7F67E5BDF587C3367A341A
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013BFFFF...
Operation took 0 minutes 2 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 5 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
IMEI: 011408001406778
Product Code:
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Done!
Done!
Done!
