Kết quả 1 tới 2 của 2
    Thành viên chính thức huyducgsm's Avatar
    Mar 2006
    Mặc định nokia 6263 unlock by mxkey.
    Phone Type: RM-207 (Nokia 6263)
    SW Version: V 04.44 24-09-07 RM-207 (c) Nokia
    Imei plain: 35698501092619-6
    Product Code: 0547828
    Language Pack:
    - not available.
    "RM-207" folder created.
    Imei net: 356985010926196
    Version: SIMLOCK SERVER
    Provider: T-Mobile, Country: U.S.A.
    Counter: 0/3, 0/10
    CONFIG_DATA: 3102000000000000
    PROFILE_BITS: 8000000000000000
    BLOCK 1: 1=LOCKED (MCC+MNC): 310160, DATA=310160
    BLOCK 2: 1=LOCKED (MCC+MNC): 310200, DATA=310200
    BLOCK 3: 1=LOCKED (MCC+MNC): 310210, DATA=310210
    BLOCK 4: 1=LOCKED (MCC+MNC): 310220, DATA=310220
    BLOCK 5: 1=LOCKED (MCC+MNC): 310230, DATA=310230
    BLOCK 6: 1=LOCKED (MCC+MNC): 310240, DATA=310240
    BLOCK 7: 1=LOCKED (MCC+MNC): 310250, DATA=310250
    BLOCK 8: 1=LOCKED (MCC+MNC): 310260, DATA=310260
    BLOCK 9: 1=LOCKED (MCC+MNC): 310270, DATA=310270
    BLOCK 10: 1=LOCKED (MCC+MNC): 310310, DATA=310310
    BLOCK 11: 1=LOCKED (MCC+MNC): 310580, DATA=310580
    BLOCK 12: 1=LOCKED (MCC+MNC): 310660, DATA=310660
    BLOCK 13: 1=LOCKED (MCC+MNC): 310800, DATA=310800
    RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-207_356985010926196_SIM.RPL"
    Updating SIMLOCK...OK
    Reading Simlock info ...
    Provider: Nokia Test, Country: Finland
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    Counter: 0/3, 0/10
    Version Info:
    MCU SW version: V 04.44 24-09-07 RM-207 (c) Nokia
    HW version: 3000
    RFIC version: 17141715
    DSP version: 06w41pb_07w34
    LCD version: SHARP
    PPM version: V 04.44 24-09-07 RM-207 (c) Nokia NTM
    BT MCM version: KW L Retu version: 15
    Tahvo version: 22
    Content Pack version: Content: tmobusa v2 29-10-07 RM-207 (c) Nokia.
    Product Info:
    Production serial number: MGC753928
    Product code: 0547828
    Basic production code: 0542309
    Long production SN: 0
    Serial Numbers:
    IMEI plain: 356985010926196
    IMEI spare to net: 3A 65 89 05 01 29 16 09
    IMEI SV to net: 33 65 89 05 01 29 16 19 F1
    Other Info:
    Model : Nokia 6263 (Fashion Phone)
    CS type : GSM850/GSM900/GSM1800/GSM1900/WCDMA IV
    BSI: 4.6 KOhm
    Counter: 0/3, 0/10
    Thành viên mới sarath6's Avatar
    May 2011
    thanks a lot ,
    you can also go here and unlock your mobile,
    I recently unlock my Nokia mobile phone using the unlock code. i heard that using unlock code to unlock the mobile is the best way. because while using the software or calculator or some other devices may results in damage to phone. using unlock code is the best way... i got the unlock code from this site prounlocking.com at reliable cost...
  1. nokia 1661 unlock by mxkey ok
    By nokiamoto in forum MX-KEY (by Alim Hape)
    Trả lời: 15
    Bài viết cuối: 16-01-2012, 15:41
  2. xin file nokia 6263 có tv
    By mjnhtuan123 in forum BB5
    Bài viết cuối: 05-11-2011, 09:38
  3. Trả lời: 3
    Bài viết cuối: 02-01-2011, 22:26
  4. MXKEY - First in the world REAL unlock for Nokia 1202, 1661, 1662, 5030
    By TUYHOAGSM™ in forum MX-KEY (by Alim Hape)
    Trả lời: 19
    Bài viết cuối: 12-04-2010, 23:36
  5. 6263 RM_207 unlock??
    By Phúc_Cần Thơ in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 13-06-2009, 22:10
